My intent is to realize 5 axis encoder analogue signal ..... at these time I have 32000 max jitter for 2 hour of youtube videos with debian wheezy ..... with ubuntu 10.04 only 17000 ......
I have run 20 time myfirst configuration and some time have a realtime error equal to ubuntu ..... release is not important .... is important new-realtime.
PCW I have already disable audio from bios... fan at standard up .... I try to attach the config if you see anythings to do.
File Name:
k1v2.hal
File Size:15.39 KB
File Name:
k1v2.ini
File Size:3.56 KB
:blush: if the solution is change motherboard I accept any suggest
for language question ..... if install debian whit italian support the intallation fal !! If install whit english support is all OK!!
