mesa card 5i25 kernel error
11 years 2 weeks ago #63894 by bkt
Replied by bkt on topic mesa card 5i25 kernel error
debian wheezy on live usb latency test whit my motherboard asrock Ad2550B mini itx is unusable ....
latency test show max jitter ~ 49000 ....
I try to install it .... but only just to do a real test for the linuxcnc people.
11 years 2 weeks ago - 11 years 1 week ago #63897 by bkt
Install processing base program failed (with the same usb pen that I used for lauch the live) ..... for make usb ped I used : sudo dd if=/xxxx/xxxx/xxx /linuxcnc2.7 wheesy.iso of=/dev/sdb && sync
I think I try wheezy linuxcnc2.7 on less older motherboard and cpu.
I make a new fresch install of ubuntu 10.04 with iso image dowloaded today from linuxcnc site download section (the iso report xxxxlinuxcnc3xxx.iso) ....
The usb live with new iso 10.04 make a max jitter with abuse of windows (move windows of latency test like a Ferrari around the screen) and see 2 videos from youtube is +/-9000 and +/-13000 .... I reinstall these distribution.....
I update at linuxcnc 2.7 these ubuntu 10.04 distro .... but there is not a 5i25 folder inside firmware/hm2 folder .... only 5i25-internal.... whitch type of file must download for obtain correct .bit .xml .xxx version for new 10.04 and linuxcnc 2.7 and 5i25 + 7i77 8only one) mesa board??????
Last edit: 11 years 1 week ago by bkt.
11 years 1 week ago - 11 years 1 week ago #63906 by PCW
Replied by PCW on topic mesa card 5i25 kernel error
You can use the 5i25 internal pncconf settings for a 7I77 so you dont need any additional
xml/pin/bit files
I would try with pncconfs 5i25-internal settings, the 5I25 programmed with 5i25_7i77x2.bit
and the 7I77 connected to the external (DB25) connector
Last edit: 11 years 1 week ago by PCW.
11 years 1 week ago #63926 by bkt
1- if try to use 5i25-internal with 7i77 one 7i77 obtain this result:
(ss0 error)
I try to use as PCW suggest 5i25-internal with 7i77x2 obtain this result:
2- IS RIGHT MY CHECK IN MESA CECK BOX SELECTION AND PARPORT?
3- obtain the selection of 7i77 mode but only 0 and 3 (in manual there are description for 0-1-2 mode ... nothing about 3 mode)
4-at the last I not see section for select DRV connector but only encoder and digital input and output and if I try to advance in configurtation obtain these result:
(You not remember to select PWM or step signal for .... axes) and the configuration can only abort.
I hope in some suggest beacuse I have buy 4 + 4 mesa card ....
11 years 1 week ago - 11 years 1 week ago #63927 by bkt
At these point I try to download from mesa site the 5i25 software .... i try to copy with sudo nautilus 5i25_7i77x2.bit 5i25_7i77x2.xml and 5i25_7i77x2.pin to new folder 5i25 in .........firmware/hm2/ ..... I try to use pnconfig but not obtain possibility to see PWM xxx axis configuration pin ... :sick: :sick: :sick: :sick:
At these point I must control that I knows on 7i77 and 5i25:
1-on pncconfig tb2 connector is 5i25 internal connector, and tb3 is external DB25 connector. Is Right?
2-in my case on TB3 panel I can select 6 encoder that I can fount during the wiring on 7i77 named on TB3 and TB4 as encoder0, encoder1...etc
3-in my case (encoder feedback and analogue command) I need 6 analogue output .... but these who are? On TB5 connector on 7i77 I hope, and named DRV0, DRV1 ... etc these selection not see at all on pncconfig panel.... no panel named TB5 or similar with new linuxcnc 2.7 release and 5i25-internal firmaware or firmaware downloaded from mesa site....
4-with selection on TB3 panel on pncconfig if select 7i77 mode 0, 1, 2, 3?? I can see (over ss0 in my case) the TB7 and TB8 panel with input output selection (these I can see) ....
Is all right that I knows about 7i77??
Point 3 is normal??
11 years 1 week ago #63932 by cncbasher
see page 4 of the 7i77 manual for connector pinouts tb2 is power
select mesa0 pci
further through the configuration you can select the firmware of the add-on card i.e 7i77x2
this then will populate the smart serial 0 ,1
and give you 2 i/o connector's 2&3 these are the channels preconfigered for servo drives ( tb5 ) & encoders ( tb3 & 4 on the 7i77 .
select smart serial0
you then have 2 tabs for connections to TB8 & TB7 ( gpio pins ) of the 7i77
which give you 16 inputs & 8 outputs per connector
select smart serial 1 this is the servo drive setup ( pwm ) on TB5
select your x axis etc to drive number here i.e drive 0 = Z drive1=y etc
does this help ?
The following user(s) said Thank You: bkt
Time to create page: 0.289 seconds
