mesa card 5i25 kernel error
11 years 1 week ago #64098 by bkt
Replied by bkt on topic mesa card 5i25 kernel error
this sound not very good ..... I build 12 machine with these motherboard (3 parallel port).... nothings about rtai error .....
@PCW not understand very well your words .... If set 2Khz servo thread this might solve the problem?
Latency test with weezy is not so good as with ubuntu 10.04 this probably is the problem. the max jtter is almost 2 time than ubuntu 10.04 ..... tomorrow I try to install new iso ubuntu 10.04 and linuxcnc 2.6.10 .... than I make my .ini and .hal by hand .....
What is in the bios setting that can causes this rtai problem?
11 years 1 week ago - 11 years 1 week ago #64101 by PCW
Replied by PCW on topic mesa card 5i25 kernel error
Not sure whats going on, but I simply cannot duplicate _any_ of your issues here.
Start with Atom D510 (I thought it was a D525 but it was really a D510) with Ubuntu 10.04 / LinuxCNC 2.5.4
upgrade to 2.7.1 using the wiki instructions
Run pncconf and create a 3 axis config for a 5I25/7I77 using internal 5I25 data and 7i77x2 with one 7I77 option
(no issues, I assign PWM outputs on the SS1 (TB5) tab and encoders on the P3 tab)
start linuxcnc and select the just created: my_LinuxCNC_Machine
LinuxCNC starts, no errors
(its running now, I'll leave it on for a few days but I don't expect any problems)
The question is: what is different on your machine?
Last edit: 11 years 1 week ago by PCW.
The following user(s) said Thank You: bkt
11 years 1 week ago #64103 by bkt
d2550 processor .... is not d525 or d5210 .... it is similar .... this is the motherboard www.asrock.com/mb/Intel/AD2550B-ITX/index.us.asp
2Gb ram 1333Mhz .... 32Gb sata2 HD no other ... (internal graphic board).
These motherboard use UEFI bios .... I think I can disable it.
..... sorry but you ugrade directly from 2.5 to 2.7? ... I make first an upgrade to 2.6 and than to 2.7 ,,,,,
11 years 1 week ago #64106 by bkt
@PCW first It's right to download ubuntu 10.04 from linuxcnc.org?
11 years 1 week ago #64111 by PCW
1. I upgraded directly from 2.5.4 to 2.7.1
2. I dont recall how I installed the original 10.04 image since its been a few years
11 years 1 week ago #64125 by bkt
ok PCW ..... we found a second difference ..... I make a double update ... you only one step .....
These question is for PCW and CMORLEY too....
A first question your ubuntu is 10.04.4 or 10.04.0?
A second question you have installed linuxcnc-dev too or not?
A third question ... if my iso is new from linuxcnc.org repo .... I must update and upgrade (obviusly not dist-upgrade anly upgrade) the system or not?
Please reply me ..... in these way I can make a SO identical to yours. If your system works fine as you tell in the furtem mine too ...
very tanks
Regards
Giorgio
Time to create page: 0.130 seconds
