- Thank you received: 114
k-1 wrote: @PCW
Sorry .... I've a new iso from linuxcnc.org (md5sum ok) I update and upgrade the system ... reboot ... upgrade directly from linuxcnc2.5 to 2.7.1 ... reboot ... update and upgrade second time ..... :sick: :sick:
I try for test using bridgport config from BigJohnT file (many thanks for your work BigJonT) .... I cancel wathcdog line (in linuxcnc2.7.1 not exist at all these command ????) ... and run these config.
All ok no ss0 error .... but error of other type (see file ) ... is because I'm not wiring at all any motor?
Than if joke about the wiring jogwheel (for some time 5-10min wit "show hal configuration .. channel a and b of encoder 5 pin section) .... I' ve an realtime error ... than download firmware 5i25_7i77x2.bit from mesa ..... mesaflash ->install new file (for anyhhow) ... mesaflash reload and verify....nothing to do about pnCconfig .... run other time BigJohnT file modified and joke again ...... the error disappear ....
Some other action that can do for make better my system? (charge new firmware to 7i77 for example?? how?)
Regards
Giorgio
NEWS .... I try to run PNCconfig whit debian live .... copy the mymachine config folder on the usb memory ... than I reboot and run ubuntu 10.04 ... copy mymachine folder (and mymachine.conf) in linuxcnc folder and than try to run PNCconfig from ubuntu 10.04 with "modify an existing configuration" option ..... as in the past is'nt possible see SS0 and SS1 panel for configure TB5 TB7 and TB8 (at this point abort the modify)....... But mymachine.ini run ok whit axis gui as I programmed with debian ..
k-1 wrote: @PCW
Regards
Giorgio
