7i76e: MPG and Analog inputs with pncconf?
6 years 7 months ago #158986 by Arro
I noticed one more thing...
the configuration (PNCConf) of the first 4 inputs on TB6 of the MESA should be foreseen for the analog-inputs (0..3).
By the way it seems only digital variables can be selected:
Limits
Manual Spindle CW
In fact I tried to set Manual Spindle CW as variable and "it works", I mean when I give the 24 Volts as input I get the signal = TRUE.
Moreover it's not possible to set the variable "Custom Signal"... it does not remain selected.
Anyway at least the raw signal should be readable somehow, noting the changing voltage value
6 years 7 months ago #158988 by PCW
The analog value pins will only be available if you select sserial modes 1 or 2 for sserial channel 0 (via a "sserial_port_0=20xx" or similar token in the loadrt hm2_eth command line)
I doubt that pncconf supports connecting the analog signal, you must do this by hand editing the hal file
6 years 7 months ago #158992 by Arro
Thanks Peter,
Andy told me about the sserial-port connection... is that running anyway through ethernet, right ?
Is the hm2_7i76e.0.read function definitely running?
-> how to check it ?
The sserial is defined in hal as following, is it correct ?
and the input signal (defined digital) is imported from PNCConfig as following (should be corrected with the analog signal when imported correctly)
6 years 7 months ago - 6 years 7 months ago #158993 by PCW
You would need to change
sserial_port_0=00xxxx
to
sserial_port_0=20xxxx
or
sserial_port_0=10xxxx
to get access to the 7I76E analog inputs
Last edit: 6 years 7 months ago by PCW.
6 years 7 months ago #158995 by Arro
will give a try...
finally I can read-in the analog input value from "hm2_7i76e.0.7i76.0.0.input-00"
-> how to define a variable where to store it
net "variable" <= hm2_7i76e.0.7i76.0.0.input-00 ?
6 years 7 months ago #158996 by Arro
what does define 20xxxx or 10xxxx ?
Time to create page: 0.494 seconds
