7i76e: MPG and Analog inputs with pncconf?
6 years 7 months ago #158997 by Arro
smart serial definition on PNCConfig
6 years 7 months ago #158999 by PCW
The net command would be something like
net 7i76_analog0 <= hm2_7i76e.0.7i76.0.0.analogin0 => some_pin
The sserial_port_0="2134XXXX" statement sets
sserial port 0 channel 0 to mode 2
sserial port 0 channel 1 to mode 1
sserial port 0 channel 2 to mode 3
sserial port 0 channel 3 to mode 4
and disables sserial port 0 channels 4..7
man hostmot2
6 years 7 months ago - 6 years 7 months ago #159000 by Arro
setting
sserial_port_0=10xxxx
I get a scaling (scalemax) for the input parameter
There should be parameters somewhere to set min and max for the raw input signal
where to find them ? (guess a correct variable definition is involved)
Last edit: 6 years 7 months ago by Arro. Reason: complete post
6 years 7 months ago - 6 years 7 months ago #159001 by PCW
halcmd show param hm2_7i76e.0.7i76*
There are no min or max parameters for analog inputs
Last edit: 6 years 7 months ago by PCW.
6 years 7 months ago - 6 years 7 months ago #159002 by Arro
got it...
have some measurement on the input, with a max-scale of 36.3 Volts it gives a reasonable value
Thank you Peter and Andy !!
6 years 7 months ago #159007 by cmorley
In fact I tried to set Manual Spindle CW as variable and "it works", I mean when I give the 24 Volts as input I get the signal = TRUE.
Moreover it's not possible to set the variable "Custom Signal"... it does not remain selected.
Anyway at least the raw signal should be readable somehow, noting the changing voltage value
You type in the combo box to make a custom signal name.
But as Peter says it only connects to the digital pin not the analog.
Time to create page: 0.071 seconds
