7i76e: MPG and Analog inputs with pncconf?
6 years 7 months ago #159008 by cmorley
PCW wrote: You would need to change
sserial_port_0=00xxxx
to
sserial_port_0=20xxxx
or
sserial_port_0=10xxxx
to get access to the 7I76E analog inputs
You can select mode 0 or 2 for the 7i76 in pncconf
6 years 7 months ago #159012 by COFHAL
How are the two MPGs configured to work simultaneously? Could you share your HAL file?
6 years 7 months ago #159057 by rodw
COFHAL wrote: How are the two MPGs configured to work simultaneously? Could you share your HAL file?
I documented it here for the 7i76e (for one axis)
forum.linuxcnc.org/show-your-stuff/32029...utter-build?start=20
6 years 7 months ago #159384 by Arro
Not using MPGs for the moment
Time to create page: 0.289 seconds
