- Thank you received: 5334
trilobyte wrote: it is working now! tnx guys!
i have this in the custom postui hal:
setp hm2_7i76e.0.7i76.0.0.analogin3-scalemax 460
net halui.maxjoganalog <= hm2_7i76e.0.7i76.0.0.analogin3 => halui.axis.jog-speed
something is a bit strange: if i start linuxcnc i can run a cnc programm without a homeing sequene (the last position is stored) but i can't move the machine with the mpg and the joystick.
with the arrow keys on the keybord it is possible directly after starting the machine.
mpg and the joystick are working after a homeing sequence, or after starting an stopping a ngc file!?
Peter
rodw wrote: PCW is on the money. In master, you can't jog until you home all. This is to prevent a gantry from racking by moving a single joint on one side.
one side.
phillc54 wrote:
I am a bit confused as I have an up to date version of master and changing the value of halui.axis.jog-speed has no effect on the jog speed slider in Axis.trilobyte wrote:
Cheers, Phill.
cmorley wrote:
Consequently, each ui has it's own idea of jograte/increment and there is no easy/universal way to communicate it around.
You would have to hack into AXIS to connect the halui jograte to AXIS's jograte - maybe possible within the .axisrc file.
