- Thank you received: 94
Hm, when I count the input pins, there are 8 at connector P1 and 8 at connector P2, which in sum are 16 or 15 as 0-based index.No, that would be input-07 (7I73 manual page 7)So to use the Pin10 of the second connector of the third 7i73 the pin-notation would be
right?Code:hm2_5i25.0.7i73.0.2.input-15
Hm, I installed hostmot2-firmware-all ...If you do not have the 5i25 installed either then that would explain the "hm2_pci not found" too.
