5i25 + 7i73
6 years 10 months ago - 6 years 10 months ago #152654 by PCW
Replied by PCW on topic 5i25 + 7i73
Sorry, copy paste error (there is no .bitt file so you probably have a 0 length file)
freeby.mesanet.com/5i24_16_sssvst8_5_1_7i47.bit
Last edit: 6 years 10 months ago by PCW.
6 years 10 months ago #152655 by Reinhard
Replied by Reinhard on topic 5i25 + 7i73
No, the file was not empty. But I did not look into it or checked size ...
... file contained html error message 404
So the right file looks quite better. I don't want muxed functions.
File Name: 5i24_pinou...2-14.txt
File Size:6.37 KB
But ... stil no smart serial success.
File Name: 5i24.hal.txt
File Size:4.94 KB
6 years 10 months ago #152656 by PCW
Do you have a straight through CAT5 cable from the 7I44 to the 7I73?
Is the 7I44 connected to P2 (top 5I24 connector)?
Is the 5I24 set to supply 5V power to the 7I44?
6 years 10 months ago #152657 by Reinhard
OK, I had the 50pin slots confused. Sorry!
Now one of the 7i33 is recognized, but led stil staying at red color.
I'm confused by the manual. For me, description of W2, W5 and W8 sounds quite the same as for W1, W3 and W6 - so I left all jumpers unchanged.
But - I changed the jumpers of daughter boards to use external power, which I provided ;)
As one of the 7i33 is recognized, I have to check/change the other patch cables.
Here's the new output of hal
File Name: 5i24_N.hal.txt
File Size:32.35 KB
Where do I change/select the hardware-/software mode of 7i73?
I'd like to use Hardware Mode 4 and Software Mode 1 or 2 (can't see any difference).
Readout from hm2_5i24 IO-Pin 069 says TxEn6 - does that mean, that each 7i73 has an enable pin?
Is that on 7i44 only, or is that routed through Ethernet cable too?
... and again my question: is there a bitfile with more stepper support for the 7i47?
6 years 10 months ago #152663 by PCW
The maximum number of step/dir channels on a 7I47 would be 6 (on the 12 TX channels)
You will not get a green light on the 7I73 until you addf the read/write functions to a thread and start the thread
6 years 10 months ago #152677 by Reinhard
I see. So the In/Out direction of the RS-422 is fix. Right?
Seems like I need another 7i47 ...
What about Siko magnetic encoders - do you know that system?
The encoder-head supports two different protocols, one A/B like standard encoders (but less exact) and then a serial protocol, which provides the absolute position data.
I'd like to use that serial protocol - is it possible with the RX-channels of a 7i47?
Time to create page: 0.071 seconds
