5i25 + 7i73
6 years 10 months ago #152269 by andypugh
Replied by andypugh on topic 5i25 + 7i73
halcmd show pin
Will show all pins.
halcmd show pin *7i73*
Should show some 7i73 pins, if there were any.
Your scope won't show anything during the HAL query, that's purely looking at data internal to HAL.
You _should_ see some activity during "loadrt hm2_pci"
And again, at 2.5 mbit, once the read and write threads start running.
6 years 10 months ago #152270 by PCW
Replied by PCW on topic 5i25 + 7i73
If the 7I73 is detected and running, the red led should go out you should get a blinking
green light
6 years 10 months ago #152283 by tommylight
Replied by tommylight on topic 5i25 + 7i73
PCW wrote: ............ (I dont have a 7I73 here but do have another sserial card=7I69).....................
I have 2, you want me to mail you one ?
On that note, i did not have time to test some LCD and some OLED screens i have with them yet. Shame on me!
6 years 10 months ago #152311 by Reinhard
Replied by Reinhard on topic 5i25 + 7i73
halcmd show all works for me
May be, we use different releases - I use git clone from master
That jack look OK but your schematic shows a CT pin which would only apply to
a jack with built in transformer, ...
Hm, I don't know much about schematics.
With eagle, I create pinouts from specs and use a schematic symbol that may match (at least if there is no pinout in specs).
show pin
Will show all pins.
Andy - thank you very much. Your reply helped me a lot in understandíng hal and what's going on :)
I'm not at that stage yet.
As I don't have a hal/ini to start linuxcnc with, I'll have to use halrun and enter each command manually.
I hope, when I can see the output of a "show pin *7i73*" I could start writing a hal/ini.
I already have three. No need for your mockery ;)
6 years 10 months ago - 6 years 10 months ago #152312 by PCW
The pinout in your schematic is not correct for a plain RJ45
Use the pinout from the 7I74 schematic:
RJ45 PIN FUNCTION 1 TXA NON-INVERTED TX 2 TXB INVERTED TX 3 RXA NON-INVERTED RX 4 GND 5 GND 6 RXB INVERTED RX 7 +5V 8 +5V
Last edit: 6 years 10 months ago by PCW.
6 years 10 months ago - 6 years 10 months ago #152313 by Reinhard
thank you for your support!
I just happened to discover the connector in your schematics and created a new symbol for eagle.
This is the new picture:
I forgot pin7 of second connector - will fix that right now.
Ah - I changed RX and TX, as I suppose, that my RX should connect to your TX - right?
Last edit: 6 years 10 months ago by Reinhard.
Time to create page: 0.398 seconds
