5i25 + 7i73
6 years 10 months ago #152647 by PCW
Replied by PCW on topic 5i25 + 7i73
The mesaflash listing is not for the 5i24_16_sssvst8_1_5_7i47.bit bitfile
did you do a --reload before testing?
6 years 10 months ago - 6 years 10 months ago #152648 by Reinhard
Replied by Reinhard on topic 5i25 + 7i73
I was not sure, so I started the box again and issued a reload from fallback ...
... and get the same result.
So yes - I did a reload before testing.
... and before you ask: I have not tried another bitfile for the 5i24
Do I need to write the bitfile in primary memory to get it working?
P.S. to find the way back to this forum-section:
I created an xml-file with mesaflash and copied the output from --readhmid into a pin-file.
Then I created a directory called "hostmot2-firmware-5i24" at /usr/share/doc and copied the xml-file to /lib/firmware/hm2/5i24 ...
... but when I select the 5i24 entry in pncconf, it traps with this error:
Traceback (most recent call last): File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 1989, in on_mesa_boardname_changed self.fill_firmware(boardnum) File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 1998, in fill_firmware self.mesa_firmware_search(title) File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 895, in mesa_firmware_search self._p.FIRMDIR,boardtitle,currentfirm+".xml")) File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 943, in parse_xml meta = self.get_board_meta(currentboard) NameError: global name 'currentboard' is not defined
What else do I have to do, to get pncconf working?
Last edit: 6 years 10 months ago by Reinhard.
6 years 10 months ago - 6 years 10 months ago #152650 by PCW
Can you try this bitfile?
freeby.mesanet.com/5i24_16_sssvst8_5_1_7i47.bit
sudo mesaflash --device 5i24 --write 5i24_16_sssvst8_5_1_7i47.bit
sudo mesaflash --device 5i24 --reload
sudo mesaflash --device 5i24 --readhmid > pinout.txt
Last edit: 6 years 10 months ago by PCW.
6 years 10 months ago #152651 by Reinhard
mesaflash says: invalid bitfile header
6 years 10 months ago - 6 years 10 months ago #152652 by PCW
what does
md5sum 5i24_16_sssvst8_5_1_7i47.bit
print?
I get
bf586d72aae6fac788f7ff95e920d912 5i24_16_sssvst8_5_1_7i47.bit
Edit: I missed the leading "b" in the first copy/paste
6 years 10 months ago #152653 by Reinhard
did you noticed, that the file, you linked has double t extension?
Might be a different file ...
md5sum 5i24_16_sssvst8_5_1_7i47.bitt 826ad9a4b51b36c805a476fcf7ddad42 5i24_16_sssvst8_5_1_7i47.bitt
