5i25 + 7i73
14 Dec 2019 05:34 #152643 by Reinhard
Replied by Reinhard on topic 5i25 + 7i73
is probably close to what you want
(assuming you have a -16 card)
Yes, I have a -16 card.
7i44 on P2 is ok, but 7i47 is not what I intended.
I want to use as much steppers on the 7i47 as possible (I read about 12 steppers).
Encoders are a later option.
At start I want to drive steppers with the 7i47, use analog channels of a 7i33 for overwrite knobs and 8x8 keypad on each 7i33 for keyboard and GPIO on 7i33 should be fast enuf for endstops or so.
PWM - yes I want pwm, but I don't know, where it will be best located.
When I buy encoders (I plan about magnetic absolute encoders with serial interface), I'll probabely have to buy another daughter for the 5i24 ...
What do you think?
14 Dec 2019 07:24 - 14 Dec 2019 10:49 #152645 by Reinhard
Argh - 400 bucks wasted and same result :(
I tested the bitfile 5i24_16_sssvst8_1_5_7i47.bit
7i47 and 7i44 connected and powered with separate power and connected 7i73 on channel 0 and channel 1
hal documentation says, that config options for 7i44 could be found in mesa doc - did not find anything in there.
So i tried the same commandline as with 5i25
halrun
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=5 num_pwmgens=1 num_stepgens=5 sserial_port_0=1110xx"
first the output from mesaflash
File Name: 5i24.txt
File Size:6 KB
next the output from loadrt hm2_pci:
File Name: 5i24_pinout.txt
File Size:4 KB
and last the output from show pin:
File Name: 5i24_pinout_X.txt
File Size:18 KB
no smartserial or any pin of a 7i73-card found.
I additionally searched the forum for 7i44, but it looks like other users needed a bitfile, but no one asked for hal config options. What am i missing?
P.S.: the 7i73 cards did not change red led
P.P.S.: i discovered the --serial option for mesaflash. Output is:
SSLBP port 0:
   SSLBP Version: 1.43
   SSLBP Channels: 8
   SSLBP Baud Rate: 2500000
Last edit: 14 Dec 2019 10:49 by Reinhard.
14 Dec 2019 11:19 #152647 by PCW
Replied by PCW on topic 5i25 + 7i73
The mesaflash listing is not for the 5i24_16_sssvst8_1_5_7i47.bit bitfile
did you do a --reload before testing?
14 Dec 2019 13:36 - 14 Dec 2019 13:50 #152648 by Reinhard
I was not sure, so I started the box again and issued a reload from fallback ...
... and get the same result.
So yes - I did a reload before testing.
... and before you ask: I have not tried another bitfile for the 5i24
Do I need to write the bitfile in primary memory to get it working?
P.S. to find the way back to this forum-section:
I created an xml-file with mesaflash and copied the output from --readhmid into a pin-file.
Then I created a directory called "hostmot2-firmware-5i24" at /usr/share/doc and copied the xml-file to /lib/firmware/hm2/5i24 ...
... but when I select the 5i24 entry in pncconf, it traps with this error:
  File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 1989, in on_mesa_boardname_changed
    self.fill_firmware(boardnum)
  File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 1998, in fill_firmware
    self.mesa_firmware_search(title)
  File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 895, in mesa_firmware_search
    self._p.FIRMDIR,boardtitle,currentfirm+".xml"))
  File "/usr/local/src/linuxcnc-dev/bin/pncconf", line 943, in parse_xml
    meta = self.get_board_meta(currentboard)
NameError: global name 'currentboard' is not defined
What else do I have to do, to get pncconf working?
Last edit: 14 Dec 2019 13:50 by Reinhard.
14 Dec 2019 15:49 - 14 Dec 2019 16:31 #152650 by PCW
Can you try this bitfile?
freeby.mesanet.com/5i24_16_sssvst8_5_1_7i47.bit
sudo mesaflash --device 5i24 --write 5i24_16_sssvst8_5_1_7i47.bit
sudo mesaflash --device 5i24 --reload
sudo mesaflash --device 5i24 --readhmid > pinout.txt
Last edit: 14 Dec 2019 16:31 by PCW.
14 Dec 2019 16:01 #152651 by Reinhard
mesaflash says: invalid bitfile header
14 Dec 2019 16:20 - 14 Dec 2019 16:23 #152652 by PCW
what does
md5sum 5i24_16_sssvst8_5_1_7i47.bit
print?
I get
bf586d72aae6fac788f7ff95e920d912 5i24_16_sssvst8_5_1_7i47.bit
Edit: I missed the leading "b" in the first copy/paste
Last edit: 14 Dec 2019 16:23 by PCW.
14 Dec 2019 16:26 #152653 by Reinhard
did you noticed, that the file, you linked has double t extension?
Might be a different file ...
md5sum 5i24_16_sssvst8_5_1_7i47.bitt
826ad9a4b51b36c805a476fcf7ddad42  5i24_16_sssvst8_5_1_7i47.bitt
14 Dec 2019 16:33 - 14 Dec 2019 16:34 #152654 by PCW
Sorry, copy paste error (there is no .bitt file so you probably have a 0 length file)
Last edit: 14 Dec 2019 16:34 by PCW.
14 Dec 2019 16:53 #152655 by Reinhard
No, the file was not empty. But I did not look into it or checked size ...
... file contained html error message 404
So the right file looks quite better. I don't want muxed functions.
File Name: 5i24_pinou...2-14.txt
File Size:6 KB
But ... stil no smart serial success.
File Name: 5i24.hal.txt
File Size:5 KB
Time to create page: 0.151 seconds
