- Thank you received: 15
Joining two motors
- Aldenflorio
6 years 2 months ago - 6 years 2 months ago #177040
by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
I will be putting the limit switches on today. I see numbers, and I’ll have to post my config files in a couple hours. I’m not with my machine now
Last edit: 6 years 2 months ago by Aldenflorio.
- Clive S
- Thank you received: 486
6 years 2 months ago - 6 years 2 months ago #177051
by Clive S
Its the homing switches that are needed for dual axis but they can also be used as combined home and limit and then setup soft limits.
linuxcnc.org/docs/2.8/html/config/ini-homing.html
Replied by Clive S on topic 2 motors on one axis
Aldenflorio wrote: I will be putting the limit switches on today. I see numbers, and I’ll have to post my config files in a couple hours. I’m not with my machine now
Last edit: 6 years 2 months ago by Clive S.
- Thank you received: 2181
6 years 2 months ago #177053
Replied by cmorley on topic 2 motors on one axis
A long time, though I havent got real world tested feedback much.
6 years 2 months ago #177055
It's still a configuration problem, as you should't be able to single joint jog a dual axis machine by default.
- Thank you received: 7491
6 years 2 months ago #177056
Replied by tommylight on topic 2 motors on one axis
No feedback = good !cmorley wrote: A long time, though I havent got real world tested feedback much.
- Aldenflorio
6 years 2 months ago - 6 years 2 months ago #177786
by Aldenflorio
sorry for the late reply it took longer then i though it would. here are my configuration files. i think
Time to create page: 2.407 seconds
