- Thank you received: 15
Joining two motors
- Aldenflorio
6 years 2 months ago - 6 years 2 months ago #176994
by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
When I do that the other motor just doesn’t move at all. I know it works bc if I press 2 then i can control it with the - and + button
Last edit: 6 years 2 months ago by Aldenflorio.
- Thank you received: 2181
6 years 2 months ago #177005
Replied by cmorley on topic 2 motors on one axis
Sounds like you are jogging in joint mode.
Do you see numbers or letter on (I assume you are using) AXIS's display?
Did you set up homing?
6 years 2 months ago #177006
Also please post you config files
- Thank you received: 7491
6 years 2 months ago #177016
Replied by tommylight on topic 2 motors on one axis
You need to home that machine first, then jog.
Do you have home switches on the machine?
- bevins
- Thank you received: 338
6 years 2 months ago #177028
by bevins
Replied by bevins on topic 2 motors on one axis
Since when does pncconf do dual motor gantries?
6 years 2 months ago #177029
Cant say for sure since i do not use it very often, but at least 6 months that i know of.
Time to create page: 2.675 seconds
