Joining two motors
6 years 2 months ago - 6 years 2 months ago #178304 by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
ok. Thank you, few more questions. i cant find where "Home Shared" is in the INI files, nor can i find immediate home (which i think i need for the z axis since it doesnt have a switch for min, just a floating head switch) another question. my ini files say that the measurements are in nanoseconds should i change that to second? if i can i would like to.
Last edit: 6 years 2 months ago by Aldenflorio.
6 years 2 months ago - 6 years 2 months ago #178305 by Clive S
Replied by Clive S on topic 2 motors on one axis
Aldenflorio wrote: ok. Thank you, few more questions. i cant find where "Home Shared" in the INI files, nor can i find immediate home (which i think i need for the z axis since it doesnt have a switch for min, just a floating head switch) another question. my ini files say that the measurements are in nanoseconds should i change that to second? if i can i would like to.
Is this for a plasma machine? The Z usually has a switch at the top
Have set this up with pncconf
Might be a good idea to post your hal and ini files
Last edit: 6 years 2 months ago by Clive S.
6 years 2 months ago - 6 years 2 months ago #178306 by Aldenflorio
Yeah plasma machine. Ok I’ll look to adding one. I’ll post the files when I get home much later. Thank you
The following user(s) said Thank You: medicusdkfz
6 years 2 months ago #178307 by Clive S
Aldenflorio wrote: Yeah plasma machine. Ok I’ll look to adding one. I’ll post the files when I get home much later. Thank you
Are you using PlasmaC. You will need a home switch at the top. The float switch will be connected later on nothing to do with homing.
6 years 2 months ago - 6 years 2 months ago #178309 by Aldenflorio
I will be once I’m finished this. It suggested having the machine fully up and set. Using a proma 150 thc. Yeah I know the floating head doesnt have anything to do with homing
6 years 2 months ago - 6 years 2 months ago #178347 by Aldenflorio
It wont let me click anything. so i cant press home all, nor can i toggle the limit switch
Time to create page: 0.154 seconds
