Joining two motors
6 years 2 months ago - 6 years 2 months ago #178358 by Clive S
Replied by Clive S on topic 2 motors on one axis
Aldenflorio wrote:
Clive S wrote:
Is this for a plasma machine? The Z usually has a switch at the top
Have set this up with pncconf
Might be a good idea to post your hal and ini files
It wont let me click anything. so i cant press home all, nor can i toggle the limit switch
You don't have any HOME_SEQUENCE = numbers in the ini file
What do you mean by:- " nor can i toggle the limit switch"
I would suggest you use halshow to see if the switches are toggling
Last edit: 6 years 2 months ago by Clive S.
6 years 2 months ago - 6 years 2 months ago #178376 by Aldenflorio
Replied by Aldenflorio on topic 2 motors on one axis
Sorry I meant e-stop. Oki thought that was strange, but I entered the sequence in the PnCConf Wizard page. Why isn’t it showing up then?
Where would I add it and what exactly would it look like?
Last edit: 6 years 2 months ago by Aldenflorio.
6 years 2 months ago #178379 by Clive S
Aldenflorio wrote: Sorry I meant e-stop. Oki thought that was strange, but I entered the sequence in the PnCConf Wizard page. Why isn’t it showing up then?
You can add it by editing the ini file using notepad or any text editor but not windows
like this
HOME_SEARCH_VEL = 40
HOME_LATCH_VEL = -2
HOME_FINAL_VEL = 50
HOME_SEQUENCE = -2
HOME_USE_INDEX = False
HOME_IGNORE_LIMITS = True
you will need it for each axis with the correct sequence numbers starting with 0 and -ve the the gantry
The following user(s) said Thank You: Aldenflorio
6 years 2 months ago - 6 years 2 months ago #178384 by Aldenflorio
Ok once I’m back at my machine I’ll add the homing sequence. Is there a reason that my PnCConf wizard isn’t creating the ini file right? I’ve had issues like this in the past
6 years 2 months ago #178423 by cmorley
Replied by cmorley on topic 2 motors on one axis
If you don't select homing pins for all axis pncconf doesn't set up home sequence properly.
6 years 2 months ago #178442 by Aldenflorio
I’ll be away for 2 weeks so I won’t be able to do anything with the table. Just putting it here so it doesn’t seem like this topic is dead
Time to create page: 0.373 seconds
