Joining two motors
6 years 1 month ago #181733 by tommylight
Replied by tommylight on topic Joining two motors
If the direction is wrong, add a - to scale, and if homing is in the wrong direction add a - to home_search_velocity.
For Z axis set it to imediate homing by omiting the home_ entries in the ini file except Home=0.
And tune the scale by using the "calibration" from the "machine" menu.
6 years 1 month ago - 6 years 1 month ago #181765 by Aldenflorio
Replied by Aldenflorio on topic Joining two motors
It’s homing in the right direction physically It just miss understands it on the display.
I’ll do that for the z axis thank you
When I edit the calibration menu nothing seems to save. I click save but when I reopen it or click refresh nothing has saved
Last edit: 6 years 1 month ago by Aldenflorio.
6 years 1 month ago #181766 by tommylight
Aldenflorio wrote: It’s homing in the right direction physically It just miss understands it on the display.
It has to be the same on display and physically, so you do need to add the - in front of the scale, also can be done in the calibration menu.
Aldenflorio wrote: When I edit the calibration menu nothing seems to save. I click save but when I reopen it or click refresh nothing has saved
Press "test" then "ok" then "save to file".
6 years 1 month ago - 6 years 1 month ago #181767 by Aldenflorio
Ok, thank you. I’ll change those things in a bit and let you know how it is
6 years 1 month ago - 6 years 1 month ago #181782 by Aldenflorio
Ok so I did as you said and things are fixed. The z axis does what I want now, the machine homes properly, and it understands which direction it’s going, and it has proper scale.
Now I need to incorporate the floating head. How do I do that? When the limit switch is triggered on the floating head it says “Joint 3 on limit switch error” then it stops moving and doesn’t allow me to jog the motors
6 years 1 month ago - 6 years 1 month ago #181892 by Aldenflorio
It give the same error message when it triggers the other limit switches that aren’t part of homing
Last edit: 6 years 1 month ago by Aldenflorio. Reason: Had to subscribe
Time to create page: 0.302 seconds
