Mesa 5i25 + 7i77D can't cofig
5 years 6 months ago - 5 years 6 months ago #207093 by bevins
OK, this is driving me nuts.
You have under axis X [JOINT_0] you are using analogout1
You should be using analogout0 for JOINT_0
So change all your analogout1 for analogout0 under # AXIS X JOINT 0
and change your analogout0 to analogout1 under AXIS Y JOINT 1
Probably wont fix your problem but will fix another problem later unless you did that on purpose.
Last edit: 5 years 6 months ago by bevins.
5 years 6 months ago #207098 by Taichi
Today in morning i changed JOINT 0 to analogout0.
I try any configs but no one works. Its not problem to change one more time.
Today i plugged external 5v to TB1 and changed jumpers for it on 5i25/7i77.
But in console system work normal and linuxCNC can't run correctly
5 years 6 months ago #207113 by Taichi
When i delete string - sserial=0x000*** from hal file
and change hm2_5i25.0.7i77.0.1.analogout0 to hm2_5i25.0.7i77.0.4.analogout0
system start normal. But halscope or halmetr don't see any change on encoder port 0. where i already connected quad encoder ROD426B.
On hand oscillograph i see square signal from A, B and X channels of this encoder
I think i did little mistake somewhere and can't find this =(
5 years 6 months ago #207114 by PCW
Replied by PCW on topic Mesa 5i25 + 7i77D can't cofig
Ok it looks to me like you have the 7I77 on the wrong connector (P2 instead of P3)
5 years 6 months ago - 5 years 6 months ago #207115 by Taichi
I connect 5i25 <<< Dsub 25 Pin male to male >>> 7i77. Its wrong??:ohmy:
Last edit: 5 years 6 months ago by Taichi.
5 years 6 months ago - 5 years 6 months ago #207117 by PCW
That's correct, P3 is the DB25 and should have the 7I77s digital and
analog I/O sserial channels 0 and 1 but they are on channels 3 and 4 in
your configuration. It looks like you have non-standard firmware loaded
in the 5I25/6I25 (probably 5i25_7i77x2r, the 'r" means reversed connectors)
Last edit: 5 years 6 months ago by PCW.
The following user(s) said Thank You: Taichi
Time to create page: 0.513 seconds
