new pnc.config won't load in linuxcnc
5 years 3 months ago #216377 by mjones@welfab.ca
Ok I got that all sorted out. it seems the pnc.config, or i some how managed to put all my pinouts onto the 7i77. I readdressed everything and now it seems to be able to see all the card, but still won't start in linuxcnc i kept trying it and reading the debut and changing little things and trying it again each time coming up with a different error until now finally it seems to have made a big step forward, and an even bigger step back. it shows a debug list a mile long. basicley saying watchdog had bit and and comunication errow then timouts on all ports. it won't let me copy it to past here and i tried creating a report file but can't find where it puts it. My interface panel isn't in the machine yet, I doubt it but its not looking for something from the machine is it?
5 years 3 months ago - 5 years 3 months ago #216381 by PCW
If you get a watchdog bite it indicates a real time issue of some kind
Can you post both your hal and ini files?
As a quick sanity check, can you report the results of these commands:
uname -a
and
ping 10.10.10.10
Last edit: 5 years 3 months ago by PCW.
5 years 3 months ago #216383 by mjones@welfab.ca
her it is.
hard@superslant:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.149 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.093 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.111 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.084 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.107 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.112 ms
^C
--- 10.10.10.10 ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 5072ms
rtt min/avg/max/mdev = 0.084/0.109/0.149/0.022 ms
hard@superslant:~$ uname -a
Linux superslant 5.0.0-32-generic #34~18.04.2-Ubuntu SMP Thu Oct 10 10:36:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
hard@superslant:~$
File Name: superslant...7-30.hal
File Size:18.46 KB
File Name: superslant.ini
File Size:4.98 KB
File Size:18.46 KB
File Size:4.98 KB
5 years 3 months ago #216386 by mjones@welfab.ca
so you know, when i start linuxcnc the leds on 7i77 and 7i64 go green for a second the out again when quits.
5 years 3 months ago #216388 by PCW
OK so the issue is that you are you are not using a real time kernel:
Did you start with the 2.8.2 ISO? it should have a 4.19.something
real time kernel
5 years 3 months ago #216392 by mjones@welfab.ca
I downloaded the linux mint in the easy install page and did all the copy and pasting it said to do. i looks like linuxcnc version is 1:2,8,2,1,9g908d16767. i don't know how to check the realtime kernel and can't find an actual linuxcnc folder to look in.
Time to create page: 0.452 seconds
