Re:pncconf - feature requests
- ericson
15 years 2 weeks ago #13837
by ericson
Replied by ericson on topic Re:pncconf - feature requests
I'm sorry I'm a newbie on this
- BigJohnT
- Thank you received: 994
15 years 2 weeks ago #13848
by BigJohnT
Replied by BigJohnT on topic Re:pncconf - feature requests
No problem the best way is to start a new thread with a subject that reflects your question. This makes it easier to find at a later date by newbee's.
- cncbasher
- Thank you received: 202
15 years 6 days ago #14246
by cncbasher
Replied by cncbasher on topic Re:pncconf - feature requests
how about adding in a copy configuration , or backup to file
yes i know we can all use the keyboard but once you have a known good configuration , it would be helpful to know you have it all backed up or can copy to a new config for further modification
including all the hidden files
- Thank you received: 2181
15 years 6 days ago #14266
Replied by cmorley on topic Re:pncconf - feature requests
actually all you need to do is load the config that you want to copy in pncconf and change the config name on the basic page and then run to the end.
It will save the config with the name you picked.
- chimpera
14 years 11 months ago #14529
by chimpera
Replied by chimpera on topic Re:pncconf - feature requests
Peter, as a new user what is the best way for me to get the 5i25+7i76 configured with steppers?
Thanks, Ben
Thanks, Ben
- Thank you received: 5334
14 years 11 months ago #14534
Replied by PCW on topic Re:pncconf - feature requests
Very crudely its:
First download EMC 2.5 (either build from source or get from buildbot)
run the hm2-stepper-5i20 demo from the EMC menu (this will copy the HAL and ini files to your
~/emc/configs/hm2-stepper directory)
Then copy the 5i20.ini in the ~/emc/configs/hm2-stepper directory to a file called 5i25 .ini
now edit this file and delete the firmware parameter in the config='xxxx" line
and change the 5I20 references to 5I25
You now have a very basic set of config files.
You may need to delete some GPIO references in the hm2-stepper.hal file as they are not appropriate to the 5I25
then run the 5i25 hm2-stepper demo from the menu...
Time to create page: 0.130 seconds
