- Thank you received: 2181
Re:pncconf - feature requests
14 years 11 months ago #14588
Replied by cmorley on topic Re:pncconf - feature requests
Yes,I think lowercase would be most consistent with hostmot2 pin names, I think.
self discovery of course would be best., but in the mean time I will just hard code the pin names for mode 0.
I'm, not sure what boards are most popular. After i code the framework adding cards should be easier.
As long as the pin names for each mode on the card don't change this will work ok.
14 years 11 months ago #14593
Replied by andypugh on topic Re:pncconf - feature requests
cmorley wrote:
Does it make more sense to hard-code the pins for mode 2?
14 years 11 months ago #14595
If there is no disadvantage to mode 2 then yes.
I see mode ADDS not replaces.
Why is there a mode 2 then?
- Thank you received: 5334
14 years 11 months ago #14596
Replied by PCW on topic Re:pncconf - feature requests
Modes may change/replace pins, (they just dont happen to on the 7I76 but do on the 7i69, 7I73 and others)
The reason that you do not just always have the maximum amount of data (like mode 2 on the 7I76)
is that it may be too much data for a given servo thread period, that is if you need a fast servo thread you may need to reduce unwanted data transfers (for example mode 2 takes an average of 24 uSec longer than mode 0 as it means the 7I76 echos 48 more bits)
We dont want to unnecessarily limit thread rates if we dont have to, especially with data that may not be used.
- BigJohnT
- Thank you received: 994
14 years 11 months ago #14599
by BigJohnT
Replied by BigJohnT on topic Re:pncconf - feature requests
That makes sense even to me.
14 years 11 months ago - 14 years 11 months ago #14600
yes I suspected this was going to be the answer.
since mode 1 or 2 doesn't add anything that PNCconf configures then mode 0 it is.
It would be trivial for the user to change modes and add the HAL commands for the pins.
Last edit: 14 years 11 months ago by cmorley.
Time to create page: 0.311 seconds
