- Thank you received: 2181
Re:pncconf - feature requests
15 years 4 weeks ago #13616
Replied by cmorley on topic Re:pncconf - feature requests
Peter do you mean for instance the 7i76 could have different components depending on something like dip switches on the board?
While I'd like PNCconf to read live systems ( and I think Andy is thinking on a mechanism) most things are predictable.
Of course it requires the user to select the right answers, which is unpredictable - but that is no worse then someone hand writing a HAL file.
For the 5i25 the user must know what firmware the board was programmed for and pick that firmware in PNCconf.
Then the user must pick the right sserial daughterboard in the right sserial channel.
then what choices are there in the sserial daughter board?
Do you see one 5i25 firmware / daughter board choice that will be heads above more popular?
Chris M
Chris M
15 years 3 weeks ago #13722
Can anyone post a print out of the HAL pins when the 7i76 is connected to the 5i25.
Thanks.
Thanks.
15 years 3 weeks ago - 15 years 3 weeks ago #13723
Replied by andypugh on topic Re:pncconf - feature requests
Not yet.
(I don't know how to wire up the 7i76 yet)
Last edit: 15 years 3 weeks ago by andypugh.
- Thank you received: 5334
15 years 3 weeks ago #13725
Replied by PCW on topic Re:pncconf - feature requests
The 7I76 can have different HAL pins depending on mode (user settable) and firmware version. Also you can connect an external SSERIAL card to the 7I76 and that card has the same possibilities, though it will show up as a a SSERIAL device
under the main FPGA card.
Only the older SSERIAL cards like the 8I20 and 7I64 have fixed pins, all new cards have modes and new modes with new pins may be added.
- ericson
15 years 2 weeks ago #13835
by ericson
Replied by ericson on topic Re:pncconf - feature requests
hi does anyone know if there is
a firmware for the 7i43 and 7i48
I have EMC2 2.5
I have EMC2 2.5
- BigJohnT
- Thank you received: 994
15 years 2 weeks ago #13836
by BigJohnT
Replied by BigJohnT on topic Re:pncconf - feature requests
Time to create page: 0.132 seconds
