- Thank you received: 994
Re:pncconf - feature requests
- BigJohnT
14 years 8 months ago #17974
by BigJohnT
Replied by BigJohnT on topic Re:pncconf - feature requests
Starting EMC2...
7i77.hal:17: parameter or pin 'hm2/hm2_5125.0.watchdog.timeout_ns' not found
Shutting down and cleaning up EMC2...
- Thank you received: 5334
14 years 8 months ago #17975
Replied by PCW on topic Re:pncconf - feature requests
so whats the "hm2/" all about?
14 years 8 months ago #17976
Replied by andypugh on topic Re:pncconf - feature requests
PCW wrote:
It's not that:
What was the complaint? it may be that 10ms (10000000 ns) is not allowed anymore and it needs to be shorter
It's not that:
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 100000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 1000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 10000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 100000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 1000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 10000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 100000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 1000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 10000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 100000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 1000000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 10000000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 100000000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 1000000000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 10000000000000000000
halcmd: setp hm2_5i23.0.watchdog.timeout_ns 100000000000000000000
halcmd: show param *ns
Parameters:
Owner Type Dir Value Name
5 u32 RW 0xFFFFFFFF hm2_5i23.0.watchdog.timeout_ns
14 years 8 months ago #17977
No, its clearly the "/hm2", not sure where that came from.
- BigJohnT
14 years 8 months ago - 14 years 8 months ago #17978
by BigJohnT
Here is the dmesg output from earlier this morning. Using this line to load the driver
loadrt hostmot2 debug_idrom=1 debug_module_descriptors=1 debug_pin_descriptors=1 debug_modules=1
Last edit: 14 years 8 months ago by BigJohnT.
14 years 8 months ago #17982
I dont think its anything low level just that the name in hal is wrong somehow. (the extraneous "/hm2")
The proper parameter name is in the parameter list (from your 5i25_7i77_pins_parameters.txt)
9 u32 RW 0x3B9ACA00 hm2_5i25.0.watchdog.timeout_ns
Time to create page: 0.309 seconds
