Gscreen - a GTK / Glade / Python based screen
12 years 2 months ago #49501 by mariusl
Replied by mariusl on topic Gscreen - a GTK / Glade / Python based screen
It is included fully into production (2.6)
Regards
Marius
www.bluearccnc.com
11 years 1 month ago #62961 by csbrady
Replied by csbrady on topic Gscreen - a GTK / Glade / Python based screen
Are there any repositories with gscreen examples? Are all of the available materials in the latest (2.7) release? I am customizing Gscreen to better fit my machine and work patterns but want to start with the latest. Examples of work from others would also be helpful.
I am slowly coming up to speed with glade, but still need to figure out the Python part.
11 years 1 month ago #62979 by cmorley
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
The latest is included with 2.7 - not much has changed other then better support for themes
There has been at least one other screen made outside of linuxcnc for a plasma machine but there are no files to share.
When your screen is finished, if it has fairly broad appeal maybe we could include it?
I have a lathe screen in the works but it will require master to work.
I will help you as much as I can to get your screen to work.
Chris M
The following user(s) said Thank You: csbrady
11 years 1 month ago #62987 by LAIR82
cmorley wrote: I have a lathe screen in the works but it will require master to work.
Chris M
Rick
11 years 1 month ago #62989 by csbrady
Thanks Chris. My customized screen will be targeted for a Bridgeport Interact with a touch screen so the appeal will be narrow. But I will be happy to make it to anyone that may be interested.
I figured out the hard way how custom python handlers work last night. I think I at last understand the process, now the actual work begins.
There are a number of buttons that I would like to remove. To do that the references in gscreen need to be overridden. It ends up being messy to do overrides so I am planning to leave the buttons in, but not make them visible. Am I on the right track?
11 years 1 month ago #63005 by cmorley
Chris M
Rick
I have been building a new screen specifically for lathes and it uses feature that only master will have.
Time will tell if it's any good :)
Chris M
Time to create page: 1.808 seconds
