- Thank you received: 2181
Gscreen - a GTK / Glade / Python based screen
csbrady wrote: There are a number of buttons that I would like to remove. To do that the references in gscreen need to be overridden. It ends up being messy to do overrides so I am planning to leave the buttons in, but not make them visible. Am I on the right track?
Yes making widgets not visible is an easy way to customise the screen.
Which 'skin' are you basing it on?
Chris M
- csbrady
- Thank you received: 10
gaxis is a less buttonny screen to start from.
i really do need to add more docs for gscreen...
looking forward to your creation
Chris M
- LAIR82
- Thank you received: 3
cmorley wrote:
I have been building a new screen specifically for lathes and it uses feature that only master will have.
Time will tell if it's any good
Chris M
I'm sure you know, we're always up for a party
RIck
- csbrady
Here are the criteria I came up with for the project:
1) Only show buttons that will get used for my implementation
2) All of the buttons needed for a particular mode are displayed, no paging through buttons.
3) All of the buttons are big enough to work well with a touch screen. They are a little small, but big enough for my 15" screen.
On power up the the Mode button is the Home button and it switches to Mode as soon when the machine is homed. I added jog + & - 0.1 buttons to make it easy to subtract / add the 0.1" offset from a 0.2" edge finder. It's really nice to be able to customize the interface for the way I work.
Most of the buttons work and I just need to work out how to tie this into HAL. Still learning ...
The gscreen samples all suffer from being development driven and not use driven.
I experimented with all kinds of methodologies, so I can see right away your screen is narrowed to what is needed, rather then a bunch of choices.
you got a name for it
Chris M
