Lathe Macros
2 years 4 months ago - 2 years 4 months ago #302989 by xenon-alien
Replied by xenon-alien on topic Lathe Macros
Forget to tell, I'm using the axis GUI and PyVCP (copy/pasted the TAB command from the *.ini files)
Here is the report of the v3.0
File Name: linuxcnc.r...v3.0.txt
File Size:11.58 KB
Here is the report of the v2.0
File Name: linuxcnc.r...v2.0.txt
File Size:11.86 KB
Last edit: 2 years 4 months ago by xenon-alien.
2 years 4 months ago - 2 years 4 months ago #302997 by Aciera
Replied by Aciera on topic Lathe Macros
File "./lathehandler.py", line 37
print 'Destroy?'
[edit]
Seems you did not get the correct version as 'lathehandler.py' in version 3 does not contain that line. So maybe try again.
Last edit: 2 years 4 months ago by Aciera.
2 years 4 months ago #303151 by xenon-alien
I used the files from the firs post, so that is why was an error...
I thought they are the same with the github v3.0, but not.
Now the LCNC is starts. Will test it later.
Thanks!
2 years 1 month ago - 2 years 1 month ago #310008 by vibram
Replied by vibram on topic Lathe Macros
 Hello,
First, thank you for the awesome work :)
I retrofiter a lathe and kept the original panel/keyboard.
This was a conversational lathe so I have keys for lathe operations such as facing etc.
I use the arduino-connector project so I'm able to define the key as an input in hal or as a keystroke or a text.
Do you think it's possible to bound a key with a macro in the cycle tab directly with one of the 3 options above?
https://media.discordapp.net/attachments/970073318810075149/1280467345164468286/IMG_20240818_085127.jpg?ex=66e40d25&is=66e2bba5&hm=6ccd4d7b9c719ef5497b92814fa29b2ab450d865d01bd02bf1aa06a6b54bb721&=&format=webp&width=900&height=676
Last edit: 2 years 1 month ago by vibram.
1 year 11 months ago - 1 year 11 months ago #313745 by mariusl
Replied by mariusl on topic Lathe Macros
I am just testing this to see how it does but cannot get it to work on 2.10.0
I get this error although Rsvg is installed.
I am on Bookworm
Traceback (most recent call last):   File "/usr/bin/gladevcp", line 379, in <module>     main()   File "/usr/bin/gladevcp", line 259, in main     handlers, mod, obj = load_handlers(opts.usermod,halcomp,builder,opts.useropts)                          ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^   File "/usr/bin/gladevcp", line 126, in load_handlers     mod = __import__(basename)           ^^^^^^^^^^^^^^^^^^^^   File "/home/plasma/linuxcnc/configs/sim.gmoccapy.lathe_configs/lathehandler.py", line 33, in <module>     gi.require_version('Rsvg', '2.0')   File "/usr/lib/python3/dist-packages/gi/__init__.py", line 126, in require_version     raise ValueError('Namespace %s not available' % namespace) ValueError: Namespace Rsvg not available
Regards
Marius
www.bluearccnc.com
Last edit: 1 year 11 months ago by mariusl.
1 year 11 months ago #313760 by Aciera
Try
sudo apt-get install gir1.2-rsvg-2.0
The following user(s) said Thank You: mariusl
Time to create page: 0.651 seconds
