I couldn't resist trying to fix this. Here is a new version of lathemacro.ui that appears to work for me.
Until yesterday, I was stuck with a broken macros screen like this when I tried to access the macros:
I went through all 40 something pages of this thread and noted everything that could be remotely relevant, then ticked them all off. Nothing fixed the issue until I changed the following line in my .ini file, in particular the "-g 300x200+0+0" element, at which point the svgs appeared and all the spinwheels, keypad etc appeared and seemed to function:
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u lathehandler.py -x {XID} -g 300x200+0+0 lathemacro.ui
Of course, the play button is greyed out and doesn't function, as noted and discussed in the above thread around post 271603. I tried that modified version of lathemacro.ui posted by AndyP, hoping this would bring the play button to life but when I substituted it for my existing copy, it reverted to a similar "broken" screen like the first one.
Obviously one simple answer would be to fit a hardware switch, as preferred by AndyP but I thought I'd just check first -
was that updated .ui file expected / intended to make the screen play button work? It's significantly different to the original 2022 .ui file when I do a file compare in VSC, so I've no idea where the critical changes actually lie. I looked at the .ui file in the Glade editor and in VSC and I can see it will take me some time to figure out what I'm looking at.
