- Thank you received: 5334
Frage wegen Spindelencoder an 7i76
1 year 11 months ago #315735
Replied by PCW on topic Frage wegen Spindelencoder an 7i76
If A does not change, that sounds like there is a problem in the "A" encoder signal path
This might be:
1. Encoder connections wrong.
2. Bad 7I76 encoder input
3. Bad / loose DB25 cable
4 7I92 bad/damaged input
Also which pin does not change? A or B?
earlier post:
When the X-axis moves, the yellow LED at A changes constantly between on and off, B remains on, Count changes between 0 and -1
latest post:
here “Count” only changes between 0 and -1, “B” flashes when I turn the encoder and “A” lights up constantly in the HAL show
This might be:
earlier post:
latest post:
- WKS-3D
- Thank you received: 16
1 year 11 months ago #315739
by WKS-3D
Replied by WKS-3D on topic Frage wegen Spindelencoder an 7i76
If I plug the complete connector, to which the encoder is connected, from the 7i76 into the 7i85, then it works.
So it can't be the cable or plug.
Possibly the input of the 7i76 is not OK.
1 year 10 months ago #315742
If you figure out which input does not work, if you have a voltmeter or just an LED
you can trace the signal at the 7I76's DB25 connector to see if the issue is with the
7I76 or 7I92.
7I76 or 7I92.
- WKS-3D
1 year 10 months ago - 1 year 10 months ago #315977
by WKS-3D
Can I plug the 7i92TM directly into the 7i76, i.e. the DB25 connectors into each other? Perhaps the ribbon cable or the connection to the plugs is defective.If you figure out which input does not work, if you have a voltmeter or just an LED
7I76 or 7I92.
Last edit: 1 year 10 months ago by WKS-3D.
1 year 10 months ago #315979
Yes, you can plug them directly together.
- WKS-3D
1 year 10 months ago #315980
by WKS-3D
Moderators: Muecke
Time to create page: 0.251 seconds
