Frage wegen Spindelencoder an 7i76
- Thank you received: 5337
01 Dec 2024 10:25 #315742
Replied by PCW on topic Frage wegen Spindelencoder an 7i76
If you figure out which input does not work, if you have a voltmeter or just an LED
you can trace the signal at the 7I76's DB25 connector to see if the issue is with the
7I76 or 7I92.
7I76 or 7I92.
- WKS-3D
- Thank you received: 16
04 Dec 2024 11:54 - 04 Dec 2024 11:55 #315977
by WKS-3D
Replied by WKS-3D on topic Frage wegen Spindelencoder an 7i76
Can I plug the 7i92TM directly into the 7i76, i.e. the DB25 connectors into each other? Perhaps the ribbon cable or the connection to the plugs is defective.If you figure out which input does not work, if you have a voltmeter or just an LED
7I76 or 7I92.
Last edit: 04 Dec 2024 11:55 by WKS-3D.
04 Dec 2024 12:12 #315979
Yes, you can plug them directly together.
- WKS-3D
04 Dec 2024 12:16 #315980
by WKS-3D
- WKS-3D
05 Dec 2024 09:41 #316021
by WKS-3D
Nun habe ich die 7i92 direkt in die 7i76 gesteckt und schau an, der Encoder 04 funktioniert jetzt auch auf der 7i76.
Da habe ich wohl beim Crimpen nicht sauber genug gearbeitet
So wie es jetzt ist, bleibt es auch.
Danke nochmals für eure Hilfe
Gruß
Olli
Now I have plugged the 7i92 directly into the 7i76 and look, the encoder 04 now also works on the 7i76.
I must not have done a clean enough job when crimping
It will stay as it is now.
Thanks again for your help
Greetings
Olli
Gruß
Olli
Greetings
Olli
- Thank you received: 7504
05 Dec 2024 10:35 #316026
Replied by tommylight on topic Frage wegen Spindelencoder an 7i76
Danke fur die ruckmeldung.
Is that written correctly? I need more practice as i do not want to forget German.
- WKS-3D
05 Dec 2024 10:43 #316027
by WKS-3D
für die Rückmeldung üüüüüüüüDanke fur die ruckmeldung.
Moderators: Muecke
Time to create page: 0.146 seconds
