7i96s Watchdog Ethernet
1 year 6 months ago #326170 by ErwinCNC
Replied by ErwinCNC on topic 7i96s Watchdog Ethernet
Hallo PCW,
hier die Messung für 10 Minuten
Der Max Ping scheint relativ hoch
Grüße Erwin
1 year 6 months ago #326171 by ErwinCNC
Hello Tommylight,
here my BIOS Settings.
Any Idea what I should change?
I will download the iso and try
What is the difference to the standard iso?
Erwin
Also my Results for a longer measure period
1 year 6 months ago #326173 by PCW
Replied by PCW on topic 7i96s Watchdog Ethernet
in the BIOS, at a minimum, Disable AMT
The following user(s) said Thank You: ErwinCNC
1 year 6 months ago #326175 by ErwinCNC
Did you mean this?
1 year 6 months ago - 1 year 6 months ago #326178 by PCW
AMT is still enabled
I think you need to enter MEBx to disable AMT
I would do a web search in the steps needed for this
on your particular CPU.
Also, posting your hal/ini files might help, getting a watchdog bite without a
"error finishing read"  is a bit odd
Last edit: 1 year 6 months ago by PCW.
1 year 6 months ago #326205 by ErwinCNC
Hi Tommylight,
I installed your iso
Without any changes I get these Results
In a short test without Watchdog error
Next step is define the grub Parameter. But there's no grub customizer
Regards
Erwin
Moderators: Muecke
Time to create page: 0.465 seconds
