7i96s Watchdog Ethernet
1 year 6 months ago #326206 by PCW
Replied by PCW on topic 7i96s Watchdog Ethernet
Please post you hal/ini files
something basic is wrong with them
The following user(s) said Thank You: ErwinCNC
1 year 6 months ago #326208 by ErwinCNC
Replied by ErwinCNC on topic 7i96s Watchdog Ethernet
here are my config files for the machine
Due to the problems I have disconnected the motors. As a test, I had one motor rotating freely on the controller - no difference. I now have an oscilloscope and can check the output of the motor signals if necessary. Currently, only the Ethernet cable and the power supply are connected to the Mesa 7i96s.
Created with PnConf Standard with minimal settings. No limit switches and no sensors. Settings for my JMC cl stepper (microsteps, 5mm/rev ...)
Maybe I have a fundamental error in the configuration?
1 year 6 months ago #326224 by PCW
Yeah, there are several odd .tmax entries, not sure what they are about,
this is what I get with a simple pncconf/gmoccapy configuration:
Parameters:
Owner   Type  Dir                 Value  Name
    38  s32   RW                      0  hm2_7i96s.0.read-request.tmax
    38  s32   RW                 661312  hm2_7i96s.0.read.tmax
    38  s32   RW                  62668  hm2_7i96s.0.write.tmax
    31  s32   RW                   4296  motion-command-handler.tmax
    31  s32   RW                  43264  motion-controller.tmax
    41  s32   RW                   3464  pid.s.do-pid-calcs.tmax
    41  s32   RW                   3472  pid.x.do-pid-calcs.tmax
    41  s32   RW                   4984  pid.y.do-pid-calcs.tmax
    41  s32   RW                   2916  pid.z.do-pid-calcs.tmax
    32  s32   RW                 760744  servo-thread.tmax
Where the heck do "base.tmax" and "servo.tmax" come from?
1 year 6 months ago #326592 by ErwinCNC
Hallo PCW,
ich habe noch einige andere Einstellungen versucht aber ohne Erfolg.
Eigentlich ist das Hobby fräsen und nicht Einstellungen in Linux CNC zu testen.
Deshalb habe ich überlegt einen Raspberry Pi 5 8gb zu kaufen. Jederzeit verfügbar, ein fertiges Image, kein raten / testen, passt bequem in den Schaltschrank.
Hältst du das für sinnvoll?
Grüße Erwin
1 year 6 months ago #326598 by PCW
It's worth a try, but...
Did you actually disable AMT?
Still don't know where base.tmax" and "servo.tmax" come from.
These are suspicious as they do not exist in a standard LinuxCNC installation.
Moderators: Muecke
Time to create page: 0.256 seconds
