THC config that works.
8 years 1 month ago #117173 by tommylight
Replied by tommylight on topic THC config that works.
It is mentioned that it does not use limit switches, that should include the Z axis.
In the xml file you set the initial values for your machine and all of them can be adjusted during use.
The Z axis home and offset should be set in the ini file. This also should be set after testing on an actual machine, as in general they do not need to be edited, i use the same settings on several different machines.
7 years 10 months ago #122916 by freemoore
Replied by freemoore on topic THC config that works.
Hi Tom and company.
My proma THC turned out to be faulty and I want to say: Lukasz replaced it quickly, though I have had it for years and way out of any guarantee I expected: it's unusual to get customer service that good! Thanks Proma...
I started again with a fresh installation of the THC config you provided and a new THC. I'm going through your calibration procedure: Pressing F9 makes the Z drop til the float switch triggers. Axis retracts to 3mm, TorchOn lights up, plasma fires, ArcOK light goes on...all good. Then, the THC sends 'MoveUP' and Z axis starts rising and rising til it's maybe 50mm above the work. I lowered the voltage setting on THC unit gradually down to around 85, so Z axis stays roughly around the same height for a bit longer but then starts to rise again. So I try setting voltage to 80, and now the Z axis moves down into the work...and keeps moving down, triggers the float switch, keeps moving down til the torch is pushed out of the holder and the shroud is smashed, tip is melted etc (I should have been quicker on the Estop button!).
I thought that the purpose of THC control is to keep the arc voltage close to the set point, but i seem to have something wrong - set point too high and Z just rises and rises, too low and Z drops and drops - as if MoveUP and MoveDOWN are working the wrong way? The THC lights and the LEDs in Axis GUI agree with each other, though, I believe the wiring and pins are correct (ie I haven't wired UP to DOWN).
Any suggestions?
a
7 years 10 months ago #122918 by tommylight
Try the voltage in between 80 and 85, Proma THC can be set to be sensitive to -+1V.
Also set the TEST time longer on the THC so you can clearly identify if the UP/Down signals are correct. You can do that by holding both buttons on the THC till you get TST then release and click on the UP till you get to 10, that will give you 10 seconds to check the signals on Linuxcnc screen.
7 years 8 months ago - 7 years 8 months ago #126164 by nkp
Replied by nkp on topic THC config that works.
is there any difference
FERROR = 1
MIN_FERROR = 500
vs
FERROR = 500
Last edit: 7 years 8 months ago by nkp.
7 years 8 months ago #126165 by tommylight
Yes there is, ferror should be for high speed or rapid moves, min_ferror should be for slow moves.
I am a bit fuzzy on that, so you should confirm that.
7 years 8 months ago #126167 by nkp
Based on this:
limiting ferror = maxFerror/limitVel * vel
If ferror < minFerror :
then OK
else:
if ferror < limiting ferror :
then OK
else:
ERROR
( this is from the source )
I think that there is no difference.
Time to create page: 0.186 seconds
