THC config that works.
7 years 8 months ago #126169
Replied by tommylight on topic THC config that works.
This has been moved to the thread below where the other configs are also located, for stepper and servo step/dir systems, for use with Mesa FPGA boards.
forum.linuxcnc.org/plasma-laser/34978-th...-with-how-to?start=0
7 years 3 months ago #138627
by phoenix
Replied by phoenix on topic THC config that works.
i apologize for asking elementry things but can someone help me with gcodetools
i m using thc toma from same page it has gcode tools folder i want to add them to thc
7 years 3 months ago #138640
No need for gcodetools anynore, they are already in Inkscape.
You have to use inkscape to produce the gcode.
Read this thread from the beggining, there are infi about everything you need.
7 years 3 months ago #138706
Use ONLY this thread for issues regarding thc toma config. You have started or asked on 8 threads by now.
Already replied on another thread.
The following user(s) said Thank You: BigJohnT
7 years 3 months ago #138796
by phoenix
in toma thc why jog is not working untill i get arc ok signal
7 years 3 months ago #138797
That is the way it should be, without ArcOk there os no cutting going on, so it does not move the machine at all untill it gets that signal.
Wire the arcok signal to torch on for testing, you can do that in hal or a wire to the parallel port from torch out to arcok in.
Time to create page: 0.076 seconds
