THC config that works.
6 years 5 months ago #169740 by Aldenflorio
Replied by Aldenflorio on topic THC config that works.
Thank you. I’m not very familiar with Linux or things like this. Which of the four links would I click?
6 years 5 months ago #169744 by tommylight
Replied by tommylight on topic THC config that works.
First 2.
Later you can decide if you want to use 2.8 or 2.9 version of Linuxcnc. 2.8 is stable while 2.9 is still being developed so might have occasional issues but it is very stable so far.
Off topic -- And that reminds me:
On Linux unstable = some issue that needs precise directions just to be able to find it, usually no one notices it,
On windows patch = something has already gone horribly wrong for many, many users.
6 years 5 months ago - 6 years 5 months ago #169745 by Aldenflorio
Thank you very much! This may be the wrong place to ask, If it is I’m sorry. Does the proma thc need a relay to help protect if from the Pilot arc? And is a relay board enough isolation or do you suggest more?
Last edit: 6 years 5 months ago by Aldenflorio.
6 years 5 months ago #169748 by tommylight
Aldenflorio wrote: Thank you very much! This may be the wrong place to ask, If it is I’m sorry. Does the proma thc need a relay to help protect if from the Pilot arc? And is a relay board enough isolation or do you suggest more?
No it does not need anything.
What type of Proma ?
If THC150, all is good continue reading,
If THC SD, stop reading this and just go make a normal 3 axis config and use the machine after some adjusting of the THC. The SD is self contained so it has nothing to do with software, it just intercepts the step/dir signals going to the Z axis drive and sends it's own signals.
6 years 5 months ago #169750 by Aldenflorio
It the proma compact thc 150
6 years 5 months ago #169753 by tommylight
Aldenflorio wrote: It the proma compact thc 150
Much better, so continue reading, and very soon making some sparks.
The following user(s) said Thank You: Aldenflorio
Time to create page: 0.241 seconds
