Work with probe
- mariusl
I see that your version of Gmoccapy is a bit old and not standard any more. Did you make a lot of changes to gmoccapy?
Regards
Marius
www.bluearccnc.com
- verser
- Thank you received: 69
Just a bit old screenshot. No any changes to gmoccapy, only custom additional panels.mariusl wrote: I have those settings in the .ini file.
- mariusl
I cannot get Andy's Lathemacro to work when I have ngcgui either.
Would you mind sharing how you got Nick's Features to load and work with Gmoccapy?
Regards
Marius
www.bluearccnc.com
- verser
My translationmariusl wrote: I
Installation:
features.zip unzip to ~/linuxcnc-dev/lib/python/gladevcp/
features_gmoccapy.zip unzip to ~/linuxcnc-dev/configs/sim/gmoccapy/
In file ~/linuxcnc-dev/configs/sim/gmoccapy/gmoccapy_4_axis.ini (or your-config.ini) in section [DISPLAY] add:
after first "calculator"
Then, update only folder ~/linuxcnc-dev/lib/python/gladevcp/subroutines from github
- elf
- Thank you received: 14
LinuxCNC version is 2.6.4.
- verser
This is bug. It's corrected. Thank you for accurate description.elf wrote: Inside circle routine isn't working for me. The first -X move is executing twice, once in the python code(line 975) and once in the macro xminus_in.ngc (line 10).
