Work with probe
11 years 5 months ago #58665 by verser
Replied by verser on topic Work with probe
mariusl wrote: Ah you see I cannot run it yet on Gmoccapy so I did not test anything. Just observations.
I just fixed a bug in the source code. Take, please, the new version.
11 years 5 months ago - 11 years 5 months ago #58666 by verser
mariusl wrote: How does that work for the edges?
In the beginning you need to install the tip of the probe just above the measured corner or edge(as indicated by the colored dot on the appropriate button Probe Screen). Z_clearance sets the depth. Set all parameters. And go :) .
Last edit: 11 years 5 months ago by verser.
11 years 5 months ago #58680 by mariusl
Replied by mariusl on topic Work with probe
Thanks I uploaded the new software and now it loads. Not tested yet but will do so soon.
What is the other piece of software next to you probing stuff on your picture a couple of posts back?
Regards
Marius
www.bluearccnc.com
11 years 5 months ago #58684 by mariusl
Hi
Gmoccapy loads with the probing stuff loaded in the usertab but when I run it the system goes to MDI mode and nothing further happens. Is there some other stuff that must be installed or not?
Regards
Marius
www.bluearccnc.com
11 years 5 months ago - 11 years 5 months ago #58685 by verser
mariusl wrote: What is the other piece of software next to you probing stuff on your picture a couple of posts back?
This is Features for linuxcnc from Nick (cnc-club.ru) - construction of g-code directly from linuxcnc
11 years 5 months ago - 11 years 5 months ago #58686 by verser
mariusl wrote: Hi
I'm a little touched up installation instructions.
Check at this part
1. .ini
... [RS274NGC] FEATURES=30 SUBROUTINE_PATH = your_subroutine_path ...
2. The following files from the archive placed in:
your-folder-configuration/your_subroutine_path
all from folder "macros"
Time to create page: 0.172 seconds
