Work with probe
11 years 3 months ago #60464 by andypugh
Replied by andypugh on topic Work with probe
ruffle wrote: They might not even take effect when directly typed in but I'm not sure on that and not in front of a machine at the moment to check.
This problem exists in PyVCP. I can't recall if it is also an issue with Glade, I vaguely recall doing something about it in my lathe UI, but can't rememeber which version.
There may be some clues here:
thread.gmane.org/gmane.linux.distributions.emc.user/32397
11 years 3 months ago #60466 by ArcEye
Replied by ArcEye on topic Work with probe
This problem exists in PyVCP........
I fixed this for pyVCP a couple of years ago re spinboxes, when you hit Enter after entering a value, it updates the value.
(commit 4c092a8dfea9ed85d7d6d2388b9f9e04e51814a5)
However these are glade widgets, so no idea re them.
The following user(s) said Thank You: verser
11 years 3 months ago #60490 by verser
Replied by verser on topic Work with probe
ArcEye wrote: I fixed this for pyVCP a couple of years ago re spinboxes, when you hit Enter after entering a value, it updates the value.
"hit Enter after entering a value" also works in Probe Screen.
11 years 3 months ago #60636 by cgtull
Replied by cgtull on topic Work with probe
I am trying this out on a virtual machine not connected to a cnc. using the (SIM) --> Axis settings. Here is my error at startup.
Previuosly had to add this to the display header to get it this far.
MAX_FEED_OVERRIDE = 50
Is it possible I do not have my folders in the right locations? Ill append the axis config file below.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/clinton/linuxcnc/configs/sim/axis'
Machine configuration file is 'axis.ini'
INIFILE=/home/clinton/linuxcnc/configs/sim/axis/axis.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
RTAPI: ERROR: Unexpected realtime delay on task 1
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
Unexpected realtime delay: check dmesg for details.
**** GLADE VCP INFO: Not a libglade project, trying to load as a GTK builder project
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u python/probe_screen.py -x 75497790 probe_icons/probe_screen.glade" exited with error: 1
Killing task linuxcncsvr, PID=15705
Killing task milltask, PID=15761
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
(gladevcp:15771): libglade-WARNING **: Expected <glade-interface>. Got <interface>.
(gladevcp:15771): libglade-WARNING **: did not finish in PARSER_FINISH state
/usr/bin/gladevcp:191: GtkWarning: Unknown property: HAL_LED.pick-color-blink
builder.add_from_file(xmlname)
/usr/bin/gladevcp:191: GtkWarning: Unknown property: HAL_LED.led-shiny
/usr/bin/gladevcp:191: GtkWarning: Unknown property: HAL_LED.blink-color
/usr/bin/gladevcp:191: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
File "/usr/bin/gladevcp", line 304, in <module>
main()
File "/usr/bin/gladevcp", line 209, in main
handlers = load_handlers(opts.usermod,halcomp,builder,opts.useropts)
File "/usr/bin/gladevcp", line 111, in load_handlers
mod = __import__(basename)
File "python/probe_screen.py", line 33, in <module>
CONFIGPATH1 = os.environ
File "/usr/lib/python2.6/UserDict.py", line 22, in __getitem__
raise KeyError(key)
KeyError: 'CONFIG_DIR'
<commandline>:0: gladevcp exited without becoming ready
15705
PID TTY STAT TIME COMMAND
15761
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 5961.634388] I-pipe: Domain RTAI registered.
[ 5961.634514] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 5961.634521] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 5961.634568] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5961.634582] PIPELINE layers:
[ 5961.634628] f8963e20 9ac15d93 RTAI 200
[ 5961.634642] c085cb20 0 Linux 100
[ 5961.682214] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5961.684090] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 5961.684140] RTAI[sched]: hard timer type/freq = APIC/4124972(Hz); default timing: periodic; linear timed lists.
[ 5961.684166] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393999000 hz.
[ 5961.684323] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5961.689887] RTAI[usi]: enabled.
[ 5961.823082] RTAI[math]: loaded.
[ 5962.162209] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 5962.162213] This Message will only display once per session.
[ 5962.162215] Run the Latency Test and resolve before continuing.
[ 5962.165934]
[ 5962.165937] In recent history there were
[ 5962.165938] 5302512, 148438, 2289085, 1363668, and 2364255
[ 5962.165940] elapsed clocks between calls to the motion controller.
[ 5962.165948] This time, there were 2409494 which is so anomalously
[ 5962.165950] large that it probably signifies a problem with your
[ 5962.165952] realtime configuration. For the rest of this run of
[ 5962.165954] EMC, this message will be suppressed.
[ 5962.165955]
[ 5969.615777] RTAI[math]: unloaded.
[ 5969.689224] SCHED releases registered named ALIEN RTGLBH
[ 5969.707544] RTAI[malloc]: unloaded.
[ 5969.805863] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5969.826934] I-pipe: Domain RTAI unregistered.
[ 5969.827583] RTAI[hal]: unmounted.
Axis.ini
# EMC controller parameters for a simulated machine.
# General note: Comments can either be preceded with a # or ; - either is
# acceptable, although # is in keeping with most linux config files.
# General section
[EMC]
# Version of this INI file
VERSION = $Revision$
# Name of machine, for use with display, etc.
MACHINE = LinuxCNC-HAL-SIM-AXIS
# Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others
#DEBUG = 0x7FFFFFFF
DEBUG = 0
# Sections for display options
[DISPLAY]
DISPLAY = axis
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
# Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME = 0.100
# Path to help file
HELP_FILE = doc/help.txt
# Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET = RELATIVE
# Initial display setting for position, COMMANDED or ACTUAL
POSITION_FEEDBACK = ACTUAL
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 1.2
MAX_SPINDLE_OVERRIDE = 1.0
MAX_LINEAR_VELOCITY = 1.2
DEFAULT_LINEAR_VELOCITY = .25
# Prefix to be used
PROGRAM_PREFIX = /home/clinton/linuxcnc/nc_files
# Introductory graphic
INTRO_TIME = 5
EDITOR = gedit
TOOL_EDITOR = tooledit
INCREMENTS = 1 in, 0.1 in, 10 mil, 1 mil, 1mm, .1mm, 1/8000 in
[FILTER]
PROGRAM_EXTENSION = .png,.gif,.jpg Grayscale Depth Image
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
# Task controller section
[TASK]
# Name of task controller program, e.g., milltask
TASK = milltask
# Cycle time, in seconds, that task controller will sleep between polls
CYCLE_TIME = 0.001
# Part program interpreter section
[RS274NGC]
# File containing interpreter variables
PARAMETER_FILE = sim.var
# Motion control section
FEATURES=30
SUBROUTINE_PATH = /home/clinton/linuxcnc/configs/sim/probe_sensor_sub
[TOOLSENSOR]
# Control probe rappid feed
RAPID_FEED = 600
[EMCMOT]
EMCMOT = motmod
# Timeout for comm to emcmot, in seconds
COMM_TIMEOUT = 1.0
# Interval between tries to emcmot, in seconds
COMM_WAIT = 0.010
# BASE_PERIOD is unused in this configuration but specified in core_sim.hal
BASE_PERIOD = 0
# Servo task period, in nano-seconds
SERVO_PERIOD = 1000000
# Hardware Abstraction Layer section
[HAL]
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALFILE = core_sim.hal
HALFILE = axis_manualtoolchange.hal
HALFILE = simulated_home.hal
# list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD = save neta
# Single file that is executed after the GUI has started. Only supported by
# AXIS at this time (only AXIS creates a HAL component of its own)
#POSTGUI_HALFILE = test_postgui.hal
HALUI = halui
# Trajectory planner section
[TRAJ]
AXES = 3
COORDINATES = X Y Z
HOME = 0 0 0
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.2
POSITION_FILE = position.txt
# Axes sections
# First axis
[AXIS_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 4
MAX_ACCELERATION = 100.0
BACKLASH = 0.000
INPUT_SCALE = 4000
OUTPUT_SCALE = 1.000
MIN_LIMIT = -40.0
MAX_LIMIT = 40.0
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 20.0
HOME_LATCH_VEL = 20.0
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
HOME_SEQUENCE = 1
HOME_IS_SHARED = 1
# Second axis
[AXIS_1]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 4
BACKLASH = 0.000
INPUT_SCALE = 4000
MIN_LIMIT = -40.0
MAX_LIMIT = 40.0
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 0.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Third axis
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 4
BACKLASH = 0.000
INPUT_SCALE = 4000
MIN_LIMIT = -8.0
MAX_LIMIT = 0.0001
FERROR = 0.050
MIN_FERROR = 0.010
HOME_OFFSET = 1.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_IS_SHARED = 1
# section for main IO controller parameters
[EMCIO]
# Name of IO controller program, e.g., io
EMCIO = io
# cycle time, in seconds
CYCLE_TIME = 0.100
# tool table file
TOOL_TABLE = sim.tbl
TOOL_CHANGE_POSITION = 0 0 0
TOOL_CHANGE_QUILL_UP = 1
11 years 3 months ago - 11 years 3 months ago #60668 by ruffle
Replied by ruffle on topic Work with probe
Can I suggest a modest but potentially very useful mod for this?
A probe tip offset/compensation method.
I've bought a probe (admittedly not a Renishaw!) and getting the tip centered to any reasonable accuracy is turning out to be a right pain.
Given that the probe would always be mounted in the same orientation (not unreasonable as the cable kind of dictates a natural place and I'd mark the front of the probe body and always use that facing the front of the machine), I know that probing in -X it measures 0.12 less than +X, +Y some 0.08 more than +X and -Y 0.04 less than +X.
It's easy to measure the offsets by turning the probe through 90 degrees and probing a known face in +X so if I could enter those differences into the probe routines (it doesn't even need to be in the GUI, editing the .pref file or setting a value in the machine's .ini file would be fine) and the calculations took account of the offsets I wouldn't need to worry that the probe tip is not 100% on centre.
Any chance of getting this added? or is it already there? I see references to 'tool_offset[]' in probe_screen.py but that array doesn't seem to be set to anything (warning my Python skills are less than my levitation skills :) so I could be missing the blindingly obvious!).
Last edit: 11 years 3 months ago by ruffle.
11 years 3 months ago #60669 by andypugh
ruffle wrote: A probe tip offset/compensation method..
You can probably do this as a tool offset (ie in the tool table) for whatever tool the probe is (mine is tool 99)
I have a button for M61 T99 G43 H99
And one day I will remember to have my probe-routines check that the tool number is correct.
Time to create page: 2.612 seconds
