Work with probe
11 years 1 month ago #62118 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Work with probe
Verser,
Another future feature for the probe screen would be to add a "Save Parameters As Defaults" button to overwrite the default spinbox values to a user's custom defaults.
Just a thought.
Thanks again.
Jim
The following user(s) said Thank You: verser
11 years 1 month ago #62119 by LearningLinuxCNC
It appears that the default values are defined in the probe_screen.py file in this section of code.
self.spbtn1_search_vel.set_value( self.prefs.getpref( "ps_searchvel", 300.0, float ) ) self.spbtn1_probe_vel.set_value( self.prefs.getpref( "ps_probevel", 10.0, float ) ) self.spbtn1_z_clearance.set_value( self.prefs.getpref( "ps_z_clearance", 3.0, float ) ) self.spbtn1_probe_max.set_value( self.prefs.getpref( "ps_probe_max", 1.0, float ) ) self.spbtn1_probe_latch.set_value( self.prefs.getpref( "ps_probe_latch", 0.5, float ) ) self.spbtn1_probe_diam.set_value( self.prefs.getpref( "ps_probe_diam", 2.0, float ) ) self.spbtn1_xy_clearance.set_value( self.prefs.getpref( "ps_xy_clearance", 5.0, float ) ) self.spbtn1_edge_lenght.set_value( self.prefs.getpref( "ps_edge_lenght", 5.0, float ) )
I will update to my default values here so hopefully when my brain fails me again it won't cost a probe stylus.
The following user(s) said Thank You: thor44
11 years 1 month ago #62157 by thor44
Replied by thor44 on topic Work with probe
In my book crashing a probe ranks up there with a death in the family. So sorry to hear about the crash. Thanks for the heads up on the default settings I'll check my set up and make adjustments.
I have one of the last parts that I need to finish building my machine, now I need some time.
11 years 1 month ago #62705 by racedirector
Replied by racedirector on topic Work with probe
The famous RAPID_SPEED error has struck... just downloaded from git and installed on the axis sim. Screenshot shows the required entry in the ini DOES exist. Where to from here?
11 years 1 month ago #62710 by verser
Replied by verser on topic Work with probe
racedirector wrote: The famous RAPID_SPEED error has struck... just downloaded from git and installed on the axis sim. Screenshot shows the required entry in the ini DOES exist. Where to from here?
It is my mistake, I apologize. RAPID_FEED fixed in RAPID_SPEED in the first post in the installation instruction.
The following user(s) said Thank You: racedirector, licantrop
11 years 1 month ago #62711 by andypugh
Replied by andypugh on topic Work with probe
racedirector wrote: Screenshot shows the required entry in the ini DOES exist. Where to from here?
You may need to turn on the option of G-code access to INI parameters:
linuxcnc.org/docs/html/remap/remap.html#...i_file_configuration
Time to create page: 2.491 seconds
