Okaaaayyyyy......
So as a newb I simply copied and pasted content from the download, I did take a backup copy beforehand so I will have a look and see if it has a "Features = some_value" and move "features=30" into that section.
For the benifit of others struggling along, and for my benifit if I didn't already have "features = ***" what [section] header should it be under?
EDIT
So, some digging has found that it needs to be in the [RS274NGC] section as described
In the doc's
This is where it is in my ini file.
I have "features=30" which is all except "retain G43".
Does it matter which order the [sections] are in? I just pasted into the bottom of my existing .ini file?
I'm still missing something.....
/edit
Edit2
OK, so is there a dumbarse of the week award around here?
I had 2 sections called [RS274NGC} as a result of the copy/paste operation, it seems LinuxCNC only cares about the first one
I've now got the joint_2/Axis_2 issue that I have seen here, *somewhere*..... I seem to recall that the name was changed from Axis to Joint in later releases? At least that's what I *THINK* the "[Axis_2] Max_Limit not defined" error means.
*sigh* this better be worth it
/edit2
