Work with probe
6 years 7 months ago #160027 by COFHAL
Replied by COFHAL on topic Problem with EMBED_TAB probe
This is me INI file.
6 years 7 months ago #160032 by andypugh
EMBED_TAB_NAME=Probe Screen EMBED_TAB_COMMAND=halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u python/probe_screen.py -H probe_icons/probe_screen.hal probe_icons/probe_screen.glade EMBED_TAB_NAME = NativeCAM EMBED_TAB_COMMAND = gladevcp -x {XID} -U --catalog=mill /usr/share/linuxcnc/aux_gladevcp/NativeCAM/ncam.ui EMBED_TAB_NAME =Huanyang VFD EMBED_TAB_COMMAND = halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u handler.py huanyang.glade
I wonder if the problem is that NativeCAM is getting the {XID} of the Probe Screeen?
Try loading them all the same way (halcmd loadusr -Wn)
6 years 7 months ago #160042 by COFHAL
No, the problem is not with nativeCAM, the problem is with Huanyang VFD TAB, when I override it with # Probe TAB works fine.
6 years 7 months ago #160048 by andypugh
COFHAL wrote: No, the problem is not with nativeCAM, the problem is with Huanyang VFD TAB, when I override it with # Probe TAB works fine.
Ah, this might be because you are trying to create a tab with HAL pin names the same as the first?
The "-c gladvcp" in both lines is probably disallowed. try "loaduser gladevcp -c vfd-tab ......"
linuxcnc.org/docs/html/gui/gladevcp.html...the_hal_command_file
The following user(s) said Thank You: COFHAL
6 years 7 months ago #160052 by COFHAL
Thank. change halcmd loadusr -Wn gladevcp gladevcp -c gladevcp -x {XID} -u handler.py huanyang.glade BY halcmd loadusr -Wn gladevcp gladevcp -c vdf-tab -x {XID} -u handler.py huanyang.glade and work fine.
6 years 7 months ago - 6 years 7 months ago #160260 by Sneaky
Replied by Sneaky on topic Work with probe
Why did the topic get renamed??
That's not the reason for my post:
I have finally gotten my understanding of this thing to the point where it seems to work so that the probing does what I expect it to.
However when I run a Gcode file the machine goes to the tool change position and sits there unresponsive.
Obviously I have done something stupid (AGAIN) but for the life of me I can't find it.
I would expect a dialogue box or a message asking me to confirm tool change or something to that effect.
Any clues as to where I should look and what I should look for?
*edit*
I always ask the question THEN find the answer, but dammit the answers are well hidden.
In this case in This post on page 24 of this very thread.
Last edit: 6 years 7 months ago by Sneaky.
Time to create page: 0.223 seconds
