Work with probe
7 years 7 months ago - 7 years 7 months ago #128199 by verser
Replied by verser on topic Work with probe
My fault. In the installation instructions did not make important lines in my-mill-postgui.hal:
net tool-change probe.toolchange-change <= iocontrol.0.tool-change net tool-changed probe.toolchange-changed <= iocontrol.0.tool-changed net tool-prep-number probe.toolchange-number <= iocontrol.0.tool-prep-number
Changed (".hal correction for tool change", "del "%" from macros")
Last edit: 7 years 7 months ago by verser.
7 years 7 months ago - 7 years 7 months ago #128228 by vmihalca
Replied by vmihalca on topic Work with probe
Hi Verser, thanks for the awesome work!
I have made the changes and it does the tool change without freezing.
Now after I do an M6 T1 G43 i get an info message sayin "No tool measurement. Please take care of the entry in the tool table."
In order to use the Remap M6, I've put the probe in the spindle and measured the height of the TS Height and it got updated.
Then I've loaded a tool using either M6 T1 (tried with and without G43).
The table moves to the coordinates of the tool setter, it goes down until it touches and then I get this error:
"Probe is already tripped when starting G38.2 or G38.3 move" and it stops there...
Any idea how should I fix this?
Last edit: 7 years 7 months ago by vmihalca.
7 years 7 months ago #128230 by ikkuh
Replied by ikkuh on topic Work with probe
Does anybody know if both Probe Screen V2 for LinuxCNC and gmoccapy probing can be installed at the same time?
7 years 7 months ago #128234 by Mike_Eitel
Replied by Mike_Eitel on topic Work with probe
I have it with v1
The following user(s) said Thank You: ikkuh
7 years 7 months ago - 7 years 7 months ago #128245 by franstrein
Replied by franstrein on topic Work with probe
I run both gmoccapy and Probe v2.
This works ok, except for my issue/question on the Remap command. See my posts above,
Apparently that is being worked upon.
Frans
Last edit: 7 years 7 months ago by franstrein.
7 years 7 months ago #128267 by Ferdl
Replied by Ferdl on topic Work with probe
Thank you great, It solved the problem.
Now I can see tool path
Time to create page: 0.395 seconds
