Work with probe
- tecno
- Thank you received: 127
12 May 2019 17:06 #133582
by tecno
Interesting to see the difference from ngc files mentioned earlier.
Replied by tecno on topic Work with probe
F #<_hal[probe.ps_searchvel]>
G91
G38.2 Z #<_ini[TOOLSENSOR]MAXPROBE>
G0 Z0.26G91
G1 Z[#<_hal[probe.ps_probe_latch]>] F#<_ini[TOOLSENSOR]RAPID_SPEED>
F #<_hal[probe.ps_probevel]>
G4 P0.5
G38.2 Z[-#<_hal[probe.ps_probe_latch]>*2]Interesting to see the difference from ngc files mentioned earlier.
- Thank you received: 4153
12 May 2019 20:09 #133595
Replied by rodw on topic Work with probe
If you have overtravelled while using G38.2, you can probe away until the probe is no longer touching with G38.4 immediately after to take up any hysteresis at a slower velocity. I do this with the float switch on my plasma cutter.
- tecno
12 May 2019 20:22 #133597
by tecno
So where do I put the G38.4?
G91
G0 Z0.26
Cheers
Bengt
G91
G0 Z0.26
Cheers
Bengt
12 May 2019 20:33 #133599
Immediately after G38.2 and before you use the probe values for anything.
- tecno
12 May 2019 20:37 #133600
by tecno
G91
G38.4
G0 Z0.26
Like this?
G91
G38.4
G0 Z0.26
Like this?
12 May 2019 20:57 - 12 May 2019 20:58 #133601
I think you need two things.. Change the F rate to slow it down and also specify a probing distance. Not saying this is perfect but will give you an idea See the docs for info linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g38
Looks like I used G38.5 for some reason but its the same thing.
F#<probe_speed>
g0 z 15
;NOTE: probe with G38.n codes and set Z0 here
G38.2 Z-3 (Probe to find the surface)
F50
G38.5 Z 20
G0 Z[#5063 + 0.0] (Move to Probe Trip point + switch hysteresis)
G92 Z0 (Set Z zero)
Last edit: 12 May 2019 20:58 by rodw.
- tecno
12 May 2019 21:20 #133603
by tecno
Have to take a closer look on this, not so easy to change parameters.
I *only* need to handle the shoot-over as all parameters are set in the ngc file here in forum.linuxcnc.org/49-basic-configuratio...obe?start=260#133566 to get the manual tool-change to work.
- tecno
14 May 2019 10:04 #133716
by tecno
So,
feeling better today and thinking clearly better so here my simple solution.
G91
G1 Z0.76 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< added travel 0.5mm and slowed down Z movement
; This is commented out only for sim.
G38.2 Z-0.5
G91
G38.2 Z-0.5
- pl7i92
- Thank you received: 358
14 May 2019 10:42 #133722
by pl7i92
Replied by pl7i92 on topic Work with probe
as simply as you coudt get it
Nice if it workes
Nice if it workes
- tecno
14 May 2019 10:49 #133723
by tecno
Seems to be working OK now, have been testing with several tool changes and all is running well.
Next in line to be solved is how to measure large end mills and also figure out offset to the high speed spindle so I can measure the tools on it too.
Time to create page: 0.499 seconds
