- Thank you received: 27
Work with probe
- Vector
3 years 2 months ago - 3 years 2 months ago #277809
by Vector
Replied by Vector on topic Work with probe
Doh! There's no python-scipy, but there IS python3-scipy.
But No, once that's installed, the error stays the same.
But Yes, if we change the line to:
loadusr -Wn probe.compensation python3 ./nc_subroutines/psng/python/compensation.py
The errors change and Lo! (choral music plays)
The screen hath appeared.
Testing will have to wait until tomorrow, I've opened an issue on alkabal's project page for PSNG_V3 to alert him to the documentation and changes for Debian 12.
Thank you for everyone being there to let me text out loud while I work this through.
And does anyone know what that message is trying to communicate: "Restore modal status using fixed startup value?"
Last edit: 3 years 2 months ago by Vector. Reason: clarity
The following user(s) said Thank You: Roguish
- Vector
3 years 2 months ago #277886
by Vector
Yes, I found that by the next post... and then the line inside the psng.hal (which was passed into the glade display) has to change it's loadusr to use python3 too.
- lrak
- Thank you received: 22
3 years 2 months ago - 3 years 2 months ago #278003
by lrak
Replied by lrak on topic Work with probe
@Vector
Read what I wrote more carefully - I pointed you to the python3-fixed code that mwidlow provided. (It is closer to working).
There is a real problem that we have so many forks..
@mwidlow
Did you see this version? PSNG_V3 ?
Looking at github.com/alkabal/PSNG_V3
It fails - appears to be looking for dynamicZ.so which is not part of linuxcnc-uspace - returns this error:
@mwidlow
dynamicZ: dlopen: /usr/lib/linuxcnc/modules/dynamicZ.so: cannot open shared object file: No such file or directory
post-gui-dynamicZ.hal:6: waitpid failed /usr/bin/rtapi_app dynamicZ
post-gui-dynamicZ.hal:6: /usr/bin/rtapi_app exited without becoming ready
post-gui-dynamicZ.hal:6: insmod for dynamicZ failed, returned -1
**** PSNG_V3 INFO Place in table ****
3
**** probe_screen GETINIINFO ****
Preference file path: /home/karl/linuxcnc/configs/wells-probe/wells.pref
File "/usr/bin/gladevcp", line 346, in <module>
main()
File "/usr/bin/gladevcp", line 227, in main
handlers, mod, obj = load_handlers(opts.usermod,halcomp,builder,opts.useropts)
File "/usr/bin/gladevcp", line 135, in load_handlers
objlist = h(halcomp,builder,useropts)
File "/home/karl/linuxcnc/configs/wells-probe/nc_subroutines/psng/python/__init__.py", line 35, in get_handlers
ProbeScreenZero(halcomp, builder, useropts),
File "/home/karl/linuxcnc/configs/wells-probe/nc_subroutines/psng/python/zero.py", line 31, in __init__
super(ProbeScreenZero, self).__init__(halcomp, builder, useropts)
File "/home/karl/linuxcnc/configs/wells-probe/nc_subroutines/psng/python/base.py", line 65, in __init__
self.command = linuxcnc.command()
All of these have one error - the complete install instructions should be in README.md
I would recommend putting something like this on it:
# git clone target
# cd linuxcnc/configs/machine-name/
# ln -s ~/target/psng ; the python directory should be a sub-directory of psng.
This would allow simple upgrading via git..
Move the install_add_to_your.ini and install_add_to_your.ini to README.md
Last edit: 3 years 2 months ago by lrak.
The following user(s) said Thank You: Vector
- Vector
3 years 2 months ago #278014
by Vector
Thanks so much Irak.
Wowza, you're so right about the confusion. It's amazing we're all making the progress we are with all these forks out there.
Indeed: for me it seems like the best candidates are these two:
(a) using various attachments you point to that begin on page 65 of this thread which were posted by mwidlok to update and fix errors one may find after installing github.com/verser-git/probe_screen_v2.8 .
(b) installing this new one: github.com/alkabal/PSNG_V3 and using my experience from page 68 of this thread:
(To recap, on 2.9.x, on Bookworm, to get PSNG_V3 to install, I believe the only changes needed are to insure python3-scipy is installed and to change the loadusr line in psng.hal to python3 in place of python.)
Which brings us to your errors, Irak....
...in my install, the file your error log shows as missing does exist: /usr/lib/linuxcnc/modules/dynamicZ.so
So what is your version of LinuxCNC and of Linux?
Mine is: linuxcnc-uspace version = 2.9.0~pre1.1066.g8fd469d67
and Linux: Debian GNU/Linux 12 (bookworm), Kernel: Linux 6.1.0-11-rt-amd64
FYI, I installed both Linux and LinuxCNC on a clean machine via the default Debian repositories, then I upgraded to the current community distribution of LinuxCNC (not the one locked by Bookworm) by following the instructions Rod helped put together here: [url] linuxcnc.org/docs/2.9/html/getting-start...an_bookworm_x86_only [/url]
So, I think not only do we have troubles from a ton of different git-hub projects out there, but also a wide range of underlying install conditions.
(Irak, I *had* read your posts very carefully, but I had began trying the v2.8 install before ever posting and abandoned it because I found V3 that promised 2.9.x support... by the time you pointed to the mwidlok fixes, I was in the middle of the adventures documented on page 68 of this thread, which ended in what looks like success, so I never went back to V2.
*** Also note, I found something interesting: it seems to me that at least one difference between V2.8 and PSNG_V3 is that V3 has the Z_Eoffset_Compensation routine coded into the hal file.
(I believe that's the 'warped surface' detection routine that would let you, say, engrave on a curved surface by having the system probe it at multiple points and make a Z-corrected mesh that modifies the z-height as a function of x-y as it processes the gcode... I think of that as kindof like auto-bed leveling in 3D printing, except you're cutting into the surface instead of building onto it.)
So if all one needs are the basics, then option (a) above (the V2.
looks like it has more work going into it and therefore be easier to get working in any given condition.
However, it might not have as many features: it may be that V3 has pushed that envelope further.
It could be that this z-compensation is a 2.9 feature to start with, since that dynamicZ.so is missing for Irak.
On the other hand, that might not be true: since there's many ways to implement these features, so it could be that both versions do all the features, and the code is just in a different spot from where I found it on V3.
It might also be in the names: could be that the v2.8 is for, ahem, LinuxCNC 2.8x and the V3 is for, err, the LinuxCNC 2.9x?
I'll post back when I'm done testing my install of V3 (tho, I doubt I'll test all of the features: like rotate and this Z-corrected-mesh thingy).
- lrak
3 years 2 months ago - 3 years 2 months ago #278096
by lrak
@Vector
From Debian bookworm's latest
linuxcnc-uspace 2.9.0~pre1+git20230208.f1270d6ed7-1
What mwidlok posted I would call probe_screen_v2.9
Not clear from what you wrote - Two questions:
Do you have this working?
Including toolchanges?
- Vector
3 years 2 months ago #278101
by Vector
@Irak
OK, so at least we're both on v 2.9.
Your question about what I have working: I am hoping to test tonight, including toolchanges. I only just installed my tool height sensor last night. I have verified my hal-pins are working as expected for that and the xyz probe, but other than that, I can only claim to have the screen running and it's telling me I have to finish setup before it will operate, which I take as a positive sign.
So I'm probably slower getting a "is it working" answer than you would be.
Are you interested in updating your linuxcnc-uspace using these instructions: linuxcnc.org/docs/2.9/html/getting-start...an_bookworm_x86_only
... because it's weird that I have the dynamicZ.so object installed but you don't... I didn't do anything unusual like compile-it-all-myself.
(When I did that update procedure, the whole thing only took a few minutes and I haven't noticed any issues. )
This is indeed frustrating because while I have been a programmer for many years, I'm nonetheless too ignorant of this github/linuxcnc environment to be able to figure out where that dynamicZ.so source might be in the repository... I've searched github, and the copy I downloaded, to no avail. [ Try googling it and see what rock bands you find
I notice those procedures in the 'update linuxcnc link' (above) appear to include downloading linuxcnc-uspace-dev, but I presume that's because we might be compiling some items during this 'outside debian freeze' update, and it needs the -dev tools. I would not imagine that dynamicZ would be part of those. And moreover, (see ignorance at the beginning of this sentence) I don't see a separate repository for -dev... which I think means the -dev source should be inside the overall repository (which I tried to search) and the make scripts would pull either linux-uspace or linux-uspace-dev depending on how it's being made.
If anyone who knows where the source tree that's being updated via that link is, and how to find out why Irak is not getting dynamicZ.so, it would be helpful.
Thanks.
Thanks.
Time to create page: 0.264 seconds
