- Thank you received: 2177
Work with probe
3 years 2 months ago #277721
Replied by Aciera on topic Work with probe
To be able to help we would need your ini file and any terminal output you get when starting your config using the 'linuxcnc' command from the terminal.
The following user(s) said Thank You: Vector
- lrak
- Thank you received: 22
3 years 2 months ago - 3 years 2 months ago #277785
by lrak
Replied by lrak on topic Work with probe
@ Vector
I think you have the wrong package
Use the one listed here forum.linuxcnc.org/49-basic-configuratio...obe?start=640#276444
- install using the instructions from github.com/verser-git/probe_screen_v2.8
Both folders:
/python
/psng
need to be copied or linked under ~/linuxcnc/configs/machine-name/
You can run it from a terminal and look at the errors - if that doesn't work you might have to turn on debug.
From what you describe, it is something in the ini file? If you have other glade bits, they might interact?
Some of the install instructions are in psng/
I got it to work - could probe and zero -- BUT if I tried to run a program it claimed the tool change point was wrong.. The example section for [CHANGE_POSITION] had a silly Z = 60 which threw an error - but even when I corrected that it fails.
(See forum.linuxcnc.org/49-basic-configuratio...obe?start=660#277493 )
I'm guessing the out of range is a result of the other error.
I've started collecting some messy notes here:
lrak.net/wiki/LinuxCNC.html#mozTocId149313
I have never created a github source - wasn't sure what people here wanted to do - seems it should be yet another version called probe_screen_2.9 .
If you find what makes it work - send me an email
Both folders:
/python
/psng
Last edit: 3 years 2 months ago by lrak.
- Vector
- Thank you received: 27
3 years 2 months ago #277797
by Vector
Replied by Vector on topic Work with probe
Hey Irak, I tried that package (probe_screen_v2.
first, on about 8/7/23, and also tried probe-screen-ng on about 8/10/23.
I believe neither could work because both were giving me python 2 errors. I think I was trying to get them to work on gmoccapy.
Unless I've gotten confused. (Definite possibility).
Are you saying you got this one to work: Probe_screen_v2_8 to work?
And you got it to work on LinuxCNC version 2.9?
And you were on which GUI?
(And thank you)
(And thank you)
- Vector
3 years 2 months ago #277800
by Vector
OK, even though Irak thinks I'm on the wrong path, until I hear back, and because I actually think I'm close, I'm going to try and post where I'm at with trying to get this version of the toolprobe gui working under Axis:
github.com/alkabal/PSNG_V3/tree/Master
I'm working that one because it's the only one of the bunch that Irak lists back on page 64 of this thread (wherein everyone agrees this has gone crazy) which claims specifically to work for LinuxCNC Version 2.9.
The good news is the screen does work and display, so the python2 vs. python3 issues that I had trying to make other packages work are not a problem (at least under the AXIS GUI. While I'd be frankly happy to switch to gmoccapy or QTDragon, I've made more progress here on axis thatn gmoccapy, and QTD has only just posted the source fixes to support 5 axes, which is what I need, so for now I'm sharing and crunching on axis).
So.... question for the community:
What are the pros and cons of the following in your .ini file, in the [DISPLAY] section:
vs
From what I can see, option 1 has the advantage of not crashing if there's an error in the .hal file being pushed to the glade file by the -H switch, and of finally delivering a very zen-experience fully-grey screen (ie, no functioning glade on the probe tab). Oops, mostly this is a disadvantage.
Option 2 has the dis-advantage of crashing before starting LinuxCNC if there's a problem in the .hal file, and then telling you error screen exactly what the problem is. Ooops, I did it again: seems like mostly an advantage.
But is there a good reason for passing the .hal file in the gladevcp command?
Anyhow, the problem with the (attached) .hal file appears to be: "Pin 'probe.toolchange_change' does not exist."
So I'm going to post this while I try to figure out what was intended in probe.toolchange_change, and therefore how to fix it.
(my first guess is that the reason one needs to send the .hal file on the gladevcp command is that this pin is possibly defined in there, and the hal is crashing on me because it can't possibly connect to it's glade definition, in which case I still won't know why there's a grey zen-screen on the probe tab)
Cheers!
EMBED_TAB_COMMAND=gladevcp -c probe -x {XID} -u nc_subroutines/psng/python -H nc_subroutines/psng/psng.hal nc_subroutines/psng/psng_mod.glade
vs
EMBED_TAB_COMMAND=gladevcp -c probe -x {XID} -u nc_subroutines/psng/python nc_subroutines/psng/psng_mod.glade
Cheers!
- Vector
3 years 2 months ago #277805
by Vector
OK, I think I'm making progress.
Yes, I think my surmise that one must include the hal component in the EMBED_TAB_COMMAND is correct, because after using the terminal logging approach, it turns out the error is:
and the line 22 in the hal file is:
And the comment above that is: "Z_EOFFSET_COMPENSATION component you need sudo apt-get install python-scipy"
And then sceeerch... I'm on Bookworm, and bookworm has, you guessed it, not python-scipy in the repository.
Fork in the road perhaps... does Precious need Z_EOFFSET_COMPENSATION?? And if Precious does, then where is it, Precious?!?
I've attached Preciouses' terminal log output (go straight to the end) and the psng.hal file that's being fed to the psng_mod.glade.
**** probe_screen GETINIINFO ****
Preference file path: /home/maker/linuxcnc/configs/SaberCNC_08/SaberCNC_08.pref
nc_subroutines/psng/psng.hal:22: execv(python): No such file or directory
nc_subroutines/psng/psng.hal:22: waitpid failed python probe.compensation
nc_subroutines/psng/psng.hal:22: python exited without becoming ready
'halcmd -f nc_subroutines/psng/psng.hal' exited with 1
loadusr -Wn probe.compensation python ./nc_subroutines/psng/python/compensation.py
- phillc54
- Thank you received: 2100
3 years 2 months ago #277807
by phillc54
Replied by phillc54 on topic Work with probe
Bookworm has python3 so try python3-scipy
Time to create page: 1.546 seconds
