How to. 2 or more motors on one axis. Gantry
16 Jul 2020 09:27 - 16 Jul 2020 09:29 #174818 by rsteurer1
Hello first sorry for my English
When i use 2 Y axis coupled are there some settings for the (Probe Screen V2) (Makros) ? because i think one doesn't turn wright at probing.
thx
other movements are fine
Last edit: 16 Jul 2020 09:29 by rsteurer1.
09 Sep 2020 10:57 #181411 by kevin19
Replied by kevin19 on topic How to. 2 or more motors on one axis. Gantry
Hello, I did almost the same to have my 2 steppers in the Z axis in linuxcnc 2.9 master version but I am getting the following error, can someone help me? I am also attaching my ini and hal files to this message.
09 Sep 2020 12:20 #181425 by Clive S
Replied by Clive S on topic How to. 2 or more motors on one axis. Gantry
for a start change this in the ini file
COORDINATES = XYZ to
COORDINATES = XYZZ
The following user(s) said Thank You: kevin19
09 Sep 2020 13:40 #181440 by tommylight
Replied by tommylight on topic How to. 2 or more motors on one axis. Gantry
From your hal file:
loadrt stepgen step_type=0,0,0
should be
loadrt stepgen step_type=0,0,0,0
09 Sep 2020 14:05 #181447 by kevin19
Thank you!
30 Dec 2020 08:06 - 30 Dec 2020 08:07 #193498 by nau
Hello
My 3 axis machine have two motors on Y axis. Previously i had single home sensor on Y axis and run both Y motors operated in same time (XYZ). That configuration homing and works fine without any errors. Config is attached (working.hal and ini).
I've installed second home sensor at Y and trying to work them correctly as XYYZ. I've changed HAL and INI as recommended X and Z homing fine but Y axis can not be homed. After hitting Y sensors it's trying to go further and kill home sensors. What's wrong? Config is attached (luma.hal and ini)
I'm running 2.8.1.
Last edit: 30 Dec 2020 08:07 by nau.
30 Dec 2020 08:21 #193499 by rodw
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=xyyz kinstype=b
is the last word meant to be both?
looks like a syntax error.
The following user(s) said Thank You: nau
30 Dec 2020 08:51 #193501 by nau
[KINS]
JOINTS = 4
"man kins" says kinstype=b is correct setting. However I tried all tree ways:
1. kinstype=BOTH : same behaviour as with b and explained above. Also it is joints instead of axis in GUI.
2. kinstype=b :same as BOTH
3. skip kinstype : same behaviour as with b and BOTH but display axis correctly.
30 Dec 2020 11:28 #193512 by Clive S
[KINS]
JOINTS = 4
Have you confirmed that the sensor is working in with halshow
30 Dec 2020 12:04 #193520 by nau
Yes. All sensor change states with halshow. And works perfectly with simply XYZ configuration.
Time to create page: 0.821 seconds
