Boxford Toolchanger WITH Index -need help-
- hitchhiker
- Thank you received: 21
27 Oct 2022 12:40 #255184
by hitchhiker
Replied by hitchhiker on topic Boxford Toolchanger WITH Index -need help-
thanks andy
i open another thread because i search for a option to home via subroutine.
in the new thread i wrote about the subroutine i need...
i think this is the way i must use to get it work like mach3 the last 5 years..
the toolchanger is one of the last parts i need to do...
is it possible to home a axis with a subroutine then it should work...
27 Oct 2022 12:44 #255186
Not really. It is possible to home with the built-in homing behaviour, and then do tool-changes with a subroutine though.
Replied by andypugh on topic Boxford Toolchanger WITH Index -need help-
thanks andy
- hitchhiker
27 Oct 2022 12:49 #255187
by hitchhiker
mmmmh ok... can i activate a pin from a subroutine?
halui.homing etc?!
halui.homing etc?!
- hitchhiker
27 Oct 2022 13:30 #255192
by hitchhiker
mmmh where can i found the carousel.comp?
i need then linuxcnc 2.9?
27 Oct 2022 13:46 #255193
Do you have the boxford.comp working?
If so, try to merge this into your HAL.
That should leave the A-axis homing normally as part of the home sequence and still allow the component to control it for tool changes.
loadrt sum2
addf sum2.0 servo-thread
net A-cmd joint.2.motor-pos-cmd joint.2.motor-pos-fb sum2.0.in0
net T-cmd toolchanger.position_cmd sum2.0.in1
net S-cmd sum2.0.out stepgen.2.position-cmdThat should leave the A-axis homing normally as part of the home sequence and still allow the component to control it for tool changes.
- hitchhiker
27 Oct 2022 14:07 #255194
by hitchhiker
ok dont understand it.. but i will check it.
yes the boxford.comp works ...
the homing works.. but after the homing i need a defined fwd move and then a defined backward move to lock the turret to the pawl.. and this is where my problem is...
i want the 2 move after homeing automatic...
you understand me or?
if i home the turret the pawl is not in contact... if i change to tool2 3 4 5 6 all works but the pawl is not in contact.
to get the pawl in contact and lock i need 2 extra moves... thats all...
27 Oct 2022 14:18 #255195
The boxford comp should do the moves?
By the way, I forgot:
The rest as-documented in the toolchanger file.
net A-homed joint.2.homed toolchanger.ishomedThe rest as-documented in the toolchanger file.
- hitchhiker
27 Oct 2022 14:31 #255197
by hitchhiker
not the homing move.. the homing is by clicking home a.
but the pawl is not locked... extra moves needed.. that why i ask if it possible to make a subroutine...
home,extra moves and set to tool1.
if i do this... :home a, jog to lock position, set tool 1 as active with g43...
then i can do toolchanges correct.
but this routine on one button.. like a pyvcp button... would be perfect.
- hitchhiker
27 Oct 2022 14:43 #255199
by hitchhiker
whst means a t s -cmd?!
- hitchhiker
27 Oct 2022 20:51 #255241
by hitchhiker
Ok!
i change the position of the disc a small amount.
then i adjust home search_vel,latch,final,offset.
now i can home the turret.
i delete all about the boxford toolchanger and stsrt with a standart a axis.
if i drive fwd 4.2mm (in angular) i go over the ratchet, then i go 0.3mm back.. the turret is locked!.. but now... how i can work forward?!
whats the next to do???
how now set tool 1?!
please help
please help
Time to create page: 0.120 seconds
