Boxford Toolchanger WITH Index -need help-
- hitchhiker
- Thank you received: 21
28 Oct 2022 23:27 #255355
by hitchhiker
Replied by hitchhiker on topic Boxford Toolchanger WITH Index -need help-
thats all?! realy? tomorrow i check it..
thanks! good night! i write tomorrow:)
thanks!!!
thanks!!!
- hitchhiker
29 Oct 2022 07:43 #255367
by hitchhiker
good morning!
yes andy i edit the scale and home search and now its rotate correct.
now i must done the last thing... getting the turret correct steps fwd and backward
realy cool!
thank you!!
i write later!
realy cool!
thank you!!
i write later!
- hitchhiker
29 Oct 2022 14:12 #255382
by hitchhiker
Back again...
after some testing... i found a failure...
but i mess arround with the code...
the toolchanger.comp needs a feedback:
net apos-cmd toolchanger.position-cmd => stepgen.2.position-cmd
net toolchanger-stepgen-fb <= stepgen.2.position-fb => toolchanger.stepgen-pos-fb <<<<
thats the rason why my turret dont lock....
in my hal i edit all with the code from andy.
# ATC
####Toolchanger Component####
loadrt toolchanger
addf toolchanger servo-thread
#### SUM2 #####
loadrt sum2
addf sum2.0 servo-thread
####A-Axis Setup####
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 5000
setp stepgen.2.dirsetup 5000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net astep <= stepgen.2.step
net adir <= stepgen.2.dir
net aenable joint.2.amp-enable-out => stepgen.2.enable
net home-a => joint.2.home-sw-in
####Set Toolnumber to 1 after Homing####
net ahomed joint.2.homed halui.mdi-command-00 toolchanger.ishomed
net tool-change iocontrol.0.tool-change => toolchanger.toolchange
net tool-changed iocontrol.0.tool-changed <= toolchanger.toolchanged
net tool-number iocontrol.0.tool-prep-number => toolchanger.toolnumber
net tool-oldnumber iocontrol.0.tool-number => toolchanger.currenttoolnumber
net A-cmd joint.2.motor-pos-cmd joint.2.motor-pos-fb sum2.0.in0
net T-cmd toolchanger.position-cmd sum2.0.in1
net S-cmd sum2.0.out stepgen.2.position-cmd
Andy .. possible that you can help?!
i think i must charge your paypal account
i change the enable to ishomed...
# ATC
loadrt toolchanger
#### SUM2 #####
loadrt sum2
- hitchhiker
29 Oct 2022 19:59 #255400
by hitchhiker
hi... is it possible that when i restart linuxcnc sometimes the component not correct works.. and then if i restart.. works correct?!
i edit the comp...save
compile in terminal..
start linuxcnc
.. works
close linuxcnc... open linuxcnc.. not working correct.
restart linuxcnc..works correct...
spooky....
start linuxcnc
.. works
spooky....
- hitchhiker
30 Oct 2022 04:42 #255423
by hitchhiker
hi andy...good morning:)
i clean up my linuxcnc (ini,hal,pyvcp).
then i found a question...
you told me to use:
why have A-cmd 2 pins?
or i am wrong??
A-cmd signalname
joint....motor-pos-cmd pin1 OUT
joint....motor-pos-fb pin2 IN
sum2 .. destination
joint.N.motor-pos-cmd OUT FLOAT
The commanded position for this joint.
joint.N.motor-pos-fb IN FLOAT
The actual position for this joint.
joint.N.pos-cmd OUT FLOAT
The joint (as opposed to motor) commanded position. There may be several offsets between the joint and motor coordinates: backlash compensation, screw error compensation, and home offsets.
joint.N.pos-fb OUT FLOAT
The joint feedback position. This value is computed from the actual motor position minus joint offsets. Useful for machine visualization.
is it the same as this:
net A-cmd joint.2.motor-pos-cmd sum2.0.in0
or is there are a reason for 2 pins on a-cmd?????
thanks!
you told me to use:
or i am wrong??
A-cmd signalname
sum2 .. destination
thanks!
- Thank you received: 4648
30 Oct 2022 22:11 #255497
This is so that the A-axis feedback always _appears_ to the controller to match the command. This is so that the toolchanger does not trigger an f-error.
Replied by andypugh on topic Boxford Toolchanger WITH Index -need help-
- hitchhiker
30 Oct 2022 22:16 #255499
by hitchhiker
ok i understand.... today i start writing a own comp with the basics of the first boxford changer...
30 Oct 2022 22:38 #255503
Have you looked at the "carousel" component?
I think it might work for your changer, but if not, at least look at how it works internally.
- hitchhiker
31 Oct 2022 12:21 #255561
by hitchhiker
yes...but... i spend a lot of time into understanding the boxford comp....
now it works... i found some failures on the hardware side.. jumpers not correct..etc...... s... happends...
now i have 1 last problem... .. how can i adjust the forward and backward velocity inside a comp..... if i get this adjust... it works.. because the fwd velocity and bwd velocity very high...
if i home the a axis from the axis button its ok.
but when i do i toolchange its the max. velocity...
if i workarround in the ..ini then the toolchange works but homing takes long time...
i want to adjust it inside the comp.
is this possible????
thanks for all your help
- hitchhiker
31 Oct 2022 18:35 #255594
by hitchhiker
ok.. i got it work but....
the rotation are very fast..and the locking is very agressiv..
next... i would test it with remaping,o-code... its realy like mach3 macro... a little bit translation...
andys tip was right... do it easy........but i hanging on the boxford.comp....
my own comp does the same as mach3 but very fast... and agressiv... i dont know yet how to make slower moves inside the comp.... it would help to know but my linuxskills are very very low...
thanks
thanks
Time to create page: 0.198 seconds
