Boxford Toolchanger WITH Index -need help-
- hitchhiker
- Thank you received: 21
27 Oct 2022 22:21 #255253
by hitchhiker
Replied by hitchhiker on topic Boxford Toolchanger WITH Index -need help-
ok.. now i can home the a axis when the boxford toolchanger is comment complete out.
after homing.. closing linuxcnc.. i activate the uncomment boxford toolchanger... start linuxcnc.. works complete perfect.
now i must bring this together....
some idea?
some idea?
- Thank you received: 4654
27 Oct 2022 23:59 #255262
Replied by andypugh on topic Boxford Toolchanger WITH Index -need help-
Have you added the HAL that I suggested? If so then you should be able to home the A axis _and_ use the component.
- hitchhiker
28 Oct 2022 15:35 - 28 Oct 2022 15:38 #255304
by hitchhiker
andypugh post=255299 userid=723
ANDY SAYS :
To set the tool number to 1 (probably using M61) you would want to trigger on joint.2.is-homed (ie, once the A axis homing is complete)
One possible way to do this is with an MDI_COMMAND:
linuxcnc.org/docs/stable/html/config/ini....html#_halui_section
In the INI
[HAL]
HALUI = halui
[HALUI]
MDI_COMMAND = M61 Q1 G43
In a HAL file:
net changer-homed joint.2.is-homed => halui.mdi-command-00
ANDY SAYS :
In the INI
[HAL]
HALUI = halui
[HALUI]
In a HAL file:
Last edit: 28 Oct 2022 15:38 by hitchhiker.
- hitchhiker
28 Oct 2022 15:53 #255307
by hitchhiker
can you please explain what this do?! i want to understand pleaseDo you have the boxford.comp working?
If so, try to merge this into your HAL.
loadrt sum2 addf sum2.0 servo-thread net A-cmd joint.2.motor-pos-cmd joint.2.motor-pos-fb sum2.0.in0 net T-cmd toolchanger.position_cmd sum2.0.in1 net S-cmd sum2.0.out stepgen.2.position-cmd That should leave the A-axis homing normally as part of the home sequence and still allow the component to control it for tool changes.
- hitchhiker
28 Oct 2022 16:47 #255311
by hitchhiker
# ATC
#### SUM2 #####
#loadrt sum2
#addf sum2.0 servo-thread
#net A-cmd joint.2.motor-pos-cmd joint.2.motor-pos-fb sum2.0.in0
#net T-cmd toolchanger.position_cmd sum2.0.in1
#net S-cmd sum2.0.out stepgen.2.position-cmd
####A-Axis Setup####
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 5000
setp stepgen.2.dirsetup 5000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net astep <= stepgen.2.step
net adir <= stepgen.2.dir
net aenable joint.2.amp-enable-out => stepgen.2.enable
net apos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net apos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net home-a => joint.2.home-sw-in
####Set Toolnumber to 1 after Homing####
net ahomed joint.2.homed halui.mdi-command-00
####Toolchanger Component####
# example Hal linkages required:-
setp stepgen.2.dirhold 16000
setp stepgen.2.dirsetup 31000
## make sure accel and velocity are sensibly low or it will take off!
### must unlink these 2 to access stepgen.3.position-cmd
### and prevent continual following errors if motor-pos-fb left linked
#net apos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
#net apos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
# loading the toolchange component in .hal file
loadrt toolchanger
addf toolchanger servo-thread
net tool-change iocontrol.0.tool-change => toolchanger.toolchange
net tool-changed iocontrol.0.tool-changed <= toolchanger.toolchanged
net tool-number iocontrol.0.tool-prep-number => toolchanger.toolnumber
net tool-oldnumber iocontrol.0.tool-number => toolchanger.currenttoolnumber
net apos-cmd toolchanger.position-cmd => stepgen.2.position-cmd
net ahomed joint.2.homed => toolchanger.ishomed
can someone bring me this together... i dont understand what is A-CMD T-CMD and S-CMD..... please help....
# ATC
#### SUM2 #####
#loadrt sum2
loadrt toolchanger
28 Oct 2022 17:22 #255314
The signal names can be anything you want, I just chose A-cmd, T-Cmd and S-Cmd as that made sense to me.
A-Cmd is the signal from the motion controller, used for homing (and jogging, potentially, but it's probably best not to)
T-cmd is the commanded position from the boxford component.
S-cmd is the sum of the two commands, which is passed on to the step generator so that both the A axis and the comonent can rotate the motor.
- hitchhiker
28 Oct 2022 17:33 #255317
by hitchhiker
ok that is whst i was thinking ok... but i get every try errors when i start linuxcnc
(( could you throw a look at my posted hal above please...
28 Oct 2022 17:55 #255320
Try replacing that section above with this
# ATC
loadrt toolchanger
#### SUM2 #####
loadrt sum2
net ahomed joint.2.homed halui.mdi-command-00 toolchanger.ishomed
################################################################################Please Log in or Create an account to join the conversation.
- hitchhiker
28 Oct 2022 22:55 #255348
by hitchhiker
yes it works!!!!
but the toolchange doesnt work correct.. foward and backward must be switched...
but now i can home the turret,lock it and set tool 1 active.
now i had to learn understand the commands inside the comp.....
in some days it should work
great!
thanks!
thanks!
28 Oct 2022 23:20 #255354
Just change the stepgen scale to be negative.
But! If you do that you also need to change the sign of the homing velocities.
Time to create page: 0.860 seconds
