Boxford Toolchanger WITH Index -need help-
- Thank you received: 4648
01 Nov 2022 10:14 #255644
Replied by andypugh on topic Boxford Toolchanger WITH Index -need help-
I thought I had answered this? Change the stepgen max velocity pin value
- hitchhiker
- Thank you received: 21
01 Nov 2022 11:13 #255650
by hitchhiker
Replied by hitchhiker on topic Boxford Toolchanger WITH Index -need help-
i done it.. then the homing takes much time... and sometimes i get error from the joint...
making a remap could be easier... its all a learn process.
andy.... mod and abs function are availible in o codes right??? is there sre some examples?
thanks
thanks
01 Nov 2022 12:06 - 01 Nov 2022 12:07 #255655
I definitely remember writing a reply suggesting the use of a mux2 component to switch between two different steppgen velocity limits. Maybe I didn't send it?
Switch the mux on joint.2.homing and setp the input pins to the two required speeds in the HAL.
MOD and ABS are mathematical functions, not O-codes.
linuxcnc.org/docs/stable/html/gcode/over...ml#gcode:expressions
Last edit: 01 Nov 2022 12:07 by andypugh.
- hitchhiker
01 Nov 2022 12:47 #255658
by hitchhiker
i dont see it (mux2).
but... i think the remap is near to the mach3 macros...
abs and mod are mathe functions.. but this functions i can use inside a o-code.thats what i understand... or i am wrong???
thanks
thanks
01 Nov 2022 12:56 #255659
You can use the mathematical functions in any G-code.
Time to create page: 0.150 seconds
